Changing Route Map Question
ALIAOF_
Level 6
Level 6
I have a question related to modifying a route map.  Here is my existing route map below.  If I need to modify it and add another prefix list do I need to type the full line again otherwise it will override with only one?  For instance:
ip prefix-list map_4 permit 192.168.1.10.0/24
route-map bgp_Advertise permit 10
 match ip address prefix-list map_1 map_2 map_3 map_4
or do I just do it like this?
 match ip address prefix-list map_4
Anton Abik
Level 4
Level 4
just tested on IOS Version 12.4(25d). You can just type the one you want to add and it will be prepended.
This is my test:
PE-2#show route-map
route-map redistribute_CE-2, permit, sequence 10
Match clauses:
ip address prefix-lists: allow_ce2
Set clauses:
Policy routing matches: 0 packets, 0 bytes
*****Adding the prefix list
PE-2(config)#route-map redistribute_CE-2
PE-2(config-route-map)#match ip address prefix-list test
PE-2(config-route-map)#do show route-map
Match clauses:
ip address prefix-lists: allow_ce2 test
Set clauses:
PE-2#show run | sec route-map
route-map redistribute_CE-2 permit 10
match ip address prefix-list allow_ce2 test
Hope it helps
Anton Abik
Level 4
Level 4
This is my test:
PE-2#show route-map
Match clauses:
Set clauses:
Match clauses:
Set clauses:
Hope it helps
