11-21-2012 09:40 AM - edited 03-07-2019 10:11 AM
Hi Everyone,
From Fibre Patch Panel to switch which is around 6 feets away which cable should we use Single mode or Multi Mode?
I read that Multimode is used for shorter distances and can carry more data.
Or does it depend on type of GBIC which we use on switch side?
Office A side is
Switch module is side is 18 1000BaseX (GBIC) WS-X4418-GB
Gbic on port is
Type: 1000BaseSX
Office B end switch port is
Type: 1000BaseSX SFP
Both office is connected with fibre within same building.
Mahesh
Solved! Go to Solution.
11-21-2012 12:13 PM
Hi Mahesh,
According to your original post, both site-A and B are using 1000BASE-SX Gbics. If this is the case, you have to use Multimode fiber with these Gbics. You can't use Single mode.
Have a look at the diference below:
Cisco 1000BASE-SX GBIC
Cisco 1000BASE-LX/LH GBIC
Reza
11-21-2012 03:29 PM
Hi Reza,
Do you mean cable form Switch to Fibre patch panel right?
As both switches have these GBIC types
1000BaseSX?
11-21-2012 04:07 PM
Hi Mahesh,
Yes, since your Gbics are Multimode (SX) your cable from the patch panel to the switch also needs to be multimode.
If your Gbics were single mode (LX) than you would need to use single mode cable from the patch panel to the switch.
Reza
11-21-2012 08:43 PM
Hi Reza,
I am surprised that Multimode GBIC is working fine with single mode cable.
Any way i will swap cable with MM.
Thanks for putting the very useful info again.
MAhesh
