04-14-2008 02:12 PM - edited 03-05-2019 10:23 PM
I have a cisco 1721 with one wic adsl running properly. Then, I have installed another one and, configuring this wic, when I tried to configure pvc, the router said :
"pvc 8/32 already exists on another interface ATM0.1. Configurations will be appli
ed on interface ATM0.1."
Why does it means?
Is no possible to run both adsl wics?
Best regards
Solved! Go to Solution.
04-18-2008 12:00 PM
When using Two ADSL WICs in one 1721. The PVC on the second ADSL WIC
may not come up. For the further description you can see bug CSCsa90021
Below link which will help you for the configuration.
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a0080093e68.shtml
04-18-2008 12:00 PM
