Cisco 1721 w/ 4 Port switch (Can't hit gateway)
CIBT Inc
Hey guys,
I've been racking my head about this a few days now, thought I'd see if anybody could tell me what is wrong.  I have a c1721 with a 4 Port WIC.  I can't seem to get anything out to the internet.  I can hit the router itself, but it just wont pass any traffic.
The router can hit the internet, just anything behind the 192.168.33.0/29 network cannot.  Below is my config.
Running C1700-ADVENTERPRISEK9-M), Version 12.4(8)
CIBT Inc
Building configuration...
Current configuration : 4976 bytes
! No configuration change since last restart
version 12.4
service password-encryption
hostname HOCC-remote10
boot-start-marker
boot system flash c1700-adventerprisek9-mz.124-8.bin
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 15
clock timezone CEST 2
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.33.1
ip dhcp pool CIBT-HOCC-remote1_pool
   import all
   network 192.168.33.0 255.255.255.248
   default-router 192.168.33.1
no ip domain lookup
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key * address X.X.X.X
crypto ipsec transform-set Myset esp-3des esp-sha-hmac
crypto map mymap 10 ipsec-isakmp
set peer X.X.X.X
set transform-set Myset
match address 102
interface Ethernet5
shutdown
interface FastEthernet0
description WAN
ip address dhcp
ip nat outside
ip virtual-reassembly
speed 100
full-duplex
no cdp enable
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4  <----------------PC-------------->
interface Vlan1
ip address 192.168.33.1 255.255.255.248
ip nat inside
ip route 0.0.0.0 0.0.0.0 192.168.0.1  <----------------Upstream-------------->
ip http server
no ip http secure-server
access-list 101 deny   ip 192.168.33.0 0.0.0.255 10.1.0.0 0.0.255.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 10.2.0.0 0.0.255.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 10.3.0.0 0.0.255.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 10.4.0.0 0.0.255.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 10.5.0.0 0.0.255.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 10.6.0.0 0.0.255.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 10.7.0.0 0.0.255.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 10.8.0.0 0.0.255.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 10.9.0.0 0.0.255.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 10.10.0.0 0.0.255.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 10.11.0.0 0.0.255.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 10.12.0.0 0.0.255.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 10.14.0.0 0.0.255.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 10.15.0.0 0.0.255.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 192.168.90.0 0.0.0.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 192.168.91.0 0.0.0.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 192.168.88.0 0.0.0.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 192.168.89.0 0.0.0.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 192.168.48.0 0.0.0.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 192.168.168.0 0.0.0.255
access-list 101 deny   ip 192.168.33.0 0.0.0.255 192.168.169.0 0.0.0.255
access-list 101 permit ip 192.168.33.0 0.0.0.255 any
access-list 102 permit ip 192.168.33.0 0.0.0.255 10.1.0.0 0.0.255.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 10.2.0.0 0.0.255.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 10.3.0.0 0.0.255.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 10.4.0.0 0.0.255.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 10.5.0.0 0.0.255.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 10.6.0.0 0.0.255.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 10.7.0.0 0.0.255.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 10.8.0.0 0.0.255.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 10.9.0.0 0.0.255.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 10.10.0.0 0.0.255.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 10.11.0.0 0.0.255.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 10.12.0.0 0.0.255.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 10.14.0.0 0.0.255.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 10.15.0.0 0.0.255.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 192.168.88.0 0.0.0.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 192.168.89.0 0.0.0.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 192.168.90.0 0.0.0.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 192.168.91.0 0.0.0.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 192.168.48.0 0.0.0.255
access-list 102 permit ip 192.168.33.0 0.0.0.255 192.168.168.0 0.0.0.255
control-plane
line con 0
exec-timeout 0 0
login local
line aux 0
line vty 0 4
password 7 *
login local
ntp clock-period 17180039
ntp server Y.Y.Y.Y
end
ryates_presido
I do not see any nat translation information you matching on. I see nat inside and outside but do not see where you tell it what to nat.
ryates_presido
Here is am link sorry
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
you could create something like this:
ip access-list standard NAT
     10 permit 192.168.33.0 0.0.0.255
ip nat inside source list NAT interface outside overload
That should get you out.  I also noticed you have crypto configured and dont see any NAT exempt configuration for tunnel routing.  Do you need to configure that as well?
