Cisco 1941 K9 temp sec license.. how to manage firewall?
charlesjudd
hello,
I have a Cisco 1941 router... ipbasek9. I want to use this at home for my primar LAN->WAN interface.  So i need the Security license enabled.
I have enabled the Security temp/eval license but can not find a way to manage it.
I have tried downloading the Cisco Configuation Assitant, but this errors with "Unsupported Device type"
any help appreciated.  License output and config outbout below (please not WAN interface on 10.0.x is just internal testing WAN IP.  This device is not yet directly connected to the internet.
cisco1941#show lic
Index 1 Feature: ipbasek9
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
Index 2 Feature: securityk9
Period left: 8  weeks 4  days
License Type: Evaluation
License State: Active, Not in Use, EULA accepted
License Priority: Low
Index 3 Feature: datak9
License State: Active, Not in Use, EULA not accepted
License Priority: None
Index 4 Feature: SSL_VPN
License Count: 75/0/0  (Active/In-use/Violation)
Index 5 Feature: ios-ips-update
SHOW CONFIG
! Last configuration change at 15:47:24 PCTime Sat Dec 10 2011
! NVRAM config last updated at 15:48:21 PCTime Sat Dec 10 2011
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname cisco1941
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable password 7 053C03032243430C48
no aaa new-model
clock timezone PCTime 10
clock summer-time PCTime date Mar 30 2003 3:00 Oct 26 2003 2:00
no ipv6 cef
no ip source-route
ip cef
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.1.254
ip dhcp pool mydhcp
   network 192.168.0.0 255.255.255.0
   update dns
   default-router 192.168.0.254
   dns-server 10.0.1.1
no ip bootp server
no ip domain lookup
crypto pki trustpoint TP-self-signed-640030031
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-640030031
revocation-check none
rsakeypair TP-self-signed-640030031
crypto pki certificate chain TP-self-signed-640030031
certificate self-signed 01 nvram:IOS-Self-Sig#3.cer
license udi pid CISCO1941/K9 sn FHK1421759M
license boot module c1900 technology-package securityk9
license agent notify http://10.0.1.6:1941/clm/servlet/HttpListenServlet dummy dummy
username admin privilege 15 secret 5 $1$..pd$6F3ks..mAkRmm9n5dizpJ/
ip tcp synwait-time 10
interface GigabitEthernet0/0
description External interface
ip dhcp client hostname Cisco1941
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description internal interface$ES_LAN$
ip address 192.168.0.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip dns view-group 10.0.1.1
ip nat inside
duplex auto
speed auto
no mop enabled
router rip
version 2
network 10.0.0.0
network 192.168.0.0
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/0 overload
logging trap debugging
access-list 1 remark CCP_ACL Category=18
access-list 1 permit 192.168.0.0 0.0.0.255
no cdp run
control-plane
banner exec ^C^C
banner login ^C^C
banner motd ^Cine ***** A^C
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
password 7 073824404D06140046
login
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
ntp source GigabitEthernet0/0
ntp master
end
cadet alain
try CCP, it should be supported.
Regards.
Alain
