06-02-2005 02:02 PM - edited 03-05-2019 11:33 AM
hi there, I have two cisco 2500 routers, having AUI interfaces. both locations have DSL connection from verizon,. is there anyway i can use these routers with DSL if yes then do i need to buy any special module
06-02-2005 10:18 PM
unfortunately, the 2500 does not support xDSL. You need to get e.g. a 1700 or 2600 with an ADSL module.
GP
06-03-2005 09:04 AM
is it the same thing if i want to dial DSL with my existing DSL modem .
06-03-2005 09:18 AM
or you can guide me how we can use cisco 2500 with current LAN topology using DSL. and with Intel 24 port managed switch
06-03-2005 09:44 AM
Hello.
the only way I could see you router being integrated into a DSL solution is by connecting the Ethernet port of your ADSL router/modem to the Ethernet AUI port of your 2500. But unless you have a 2514 (which has two Ethernet ports), that would still not get you anywhere, since you need an additional Ethernet port to connect your switch...
GP
