Cisco 2600 InterVLAN routing (configuring subinterfaces)
kosalasuranjith
I tried to configure sub interfaces in our Cisco 2611 router as follows.
Router1(config)#interface fastEthernet 0/1.1
(config-subif)#ip address 172.16.2.0 255.255.255.0
but this gives the following error.
% Configuring IP routing on a LAN subinterface is only allowed if that
subinterface is already configured as part of an IEEE 802.10, IEEE 802.1Q,
or ISL vLAN.
what was the cause for this error?
Also the router does not provide encapsulation dot1Q 2 ...... commands in the subinterface mode.
Is this router not provide this feature??
Kosala
5 Replies 5
spremkumar
Level 9
Level 9
Hi Kosala
You need to make sure that your IOS supports inter vlan routing feature.
If it doesnt you need to upgrade it first to configure inter vlan routing.
regds
mfreijser
You will need IOS 12.1(3)T or higher to use the "encapsulation dot1q ..." command.
There is a workaround if you are using a earlier version of IOS and are not able to upgrade the device. It can be found on the following page:
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a00800949fd.shtml
Please rate if the post helps!
Michael
But my router, the version is newer.
Pls. check the show version output....
IOS (tm) C2600 Software (C2600-I-M), Version 12.3(17b), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Mon 06-Mar-06 22:02 by dchih
Image text-base: 0x80008098, data-base: 0x80CE0844
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
ROM: C2600 Software (C2600-I-M), Version 12.3(17b), RELEASE SOFTWARE (fc2)
SLTiDC_DR_Router1 uptime is 6 days, 18 hours, 20 minutes
Can it be the problem...?
Kosala
Kosala
You need a minimum feature set of IP Plus to support 802.1q subinterfaces.
Jon
You mean to update the IOS ??
kosala
