Cisco 2600 router and switch(3500xl) connection problem
rythem007
hi,
i was trying to connect PC-SWITCH-ROUTER
On switch Fa0/1(where switch is connected) LED(link) is ON,while On switch Fa0/0(where cisco 2600xl router is connected) LED is not blinking
But when i remove cisco 2600xl router and replaced with cisco 831 router then fa0/0 LED is ON.
i do not know what to do??
please help me to solve this issue
When you get a minute;
On the switch do a
show run interface fastethernet 0/2
on the router do a
show run interface ethernet 0/0
and paste the output, please.
Are you using a straight through cable between the switch and router?
Are both sides auto negotiating speed and duplex?
In order for the switch and router to auto-mdix, auto-negotiation needs to be enabled on both sides.
5 Replies 5
Charles Hill
Hello rythem007,
Has the port been configured and turned up(no shut) on the 2600xl router?
What is the status of the port when you do a show ip int brief and or show interface on the 2600xl?
If problem still exists, can you do a show run interface x0/0 on the switch and 2600 router and copy it and post it here on the forum?
Here i have connected PC to cisco 3500xl(fa0/1 port)
         Cisco 3500xl(fa0/2 port) to router 2600xl(ethernet0/0 port)
for cisco switch 3500xl
Interface                  IP-Address      OK? Method Status                Prot        ocol
VLAN1                      unassigned      NO  unset  up                    up
FastEthernet0/1            unassigned      YES unset  up                    up
FastEthernet0/2            unassigned      YES unset  down                  down
FastEthernet0/3            unassigned      YES unset  down                  down
FastEthernet0/4            unassigned      YES unset  down                  down
FastEthernet0/5            unassigned      YES unset  down                  down
FastEthernet0/6            unassigned      YES unset  down                  down
FastEthernet0/7            unassigned      YES unset  down                  down
FastEthernet0/8            unassigned      YES unset  down                  down
FastEthernet0/9            unassigned      YES unset  down                  down
FastEthernet0/10           unassigned      YES unset  down                  down
FastEthernet0/11           unassigned      YES unset  down                  down
FastEthernet0/12           unassigned      YES unset  down                  down
FastEthernet0/13           unassigned      YES unset  down                  down
FastEthernet0/14           unassigned      YES unset  down                  down
FastEthernet0/15           unassigned      YES unset  down                  down
FastEthernet0/16           unassigned      YES unset  down                  down
FastEthernet0/17           unassigned      YES unset  down                  down
FastEthernet0/18           unassigned      YES unset  down                  down
FastEthernet0/19           unassigned      YES unset  down                  down
FastEthernet0/20           unassigned      YES unset  down                  down
FastEthernet0/21           unassigned      YES unset  down                  down
FastEthernet0/22           unassigned      YES unset  down                  down
FastEthernet0/23           unassigned      YES unset  down                  down
FastEthernet0/24           unassigned      YES unset  down                  down
GigabitEthernet0/1         unassigned      YES unset  down                  down
GigabitEthernet0/2         unassigned      YES unset  down                  down
Switch#sh
Switch#show vl
Switch#show vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/1, Fa0/2, Fa0/3, Fa0/4,
                                                Fa0/5, Fa0/6, Fa0/7, Fa0/8,
                                                Fa0/9, Fa0/10, Fa0/11, Fa0/12,
                                                Fa0/13, Fa0/14, Fa0/15, Fa0/16,
                                                Fa0/17, Fa0/18, Fa0/19, Fa0/20,
                                                Fa0/21, Fa0/22, Fa0/23, Fa0/24,
                                                Gi0/1, Gi0/2
1002 fddi-default                     active
1003 token-ring-default               active
1004 fddinet-default                  active
1005 trnet-default                    active
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        1002   1003
1002 fddi  101002     1500  -      -      -        -    -        1      1003
1003 tr    101003     1500  1005   0      -        -    srb      1      1002
1004 fdnet 101004     1500  -      -      1        ibm  -        0      0
1005 trnet 101005     1500  -      -      1        ibm  -        0      0
now for cisco router 2600xl,
Router#show ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
Ethernet0/0                192.168.1.1     YES NVRAM  up                    down
Ethernet0/0.2              192.168.2.2     YES NVRAM  up                    down
Ethernet0/0.3              192.168.3.3     YES NVRAM  up                    down
Serial0/0                  unassigned      YES NVRAM  administratively down down
Ethernet0/1                unassigned      YES NVRAM  administratively down down
thank for reply
On the switch do a
on the router do a
Switch#show interfaces fastEthernet0/2
FastEthernet0/2 is down, line protocol is down
  Hardware is Fast Ethernet, address is 0009.43d6.0d82 (bia 0009.43d6.0d82)
  MTU 1500 bytes, BW 0 Kbit, DLY 100 usec,
  Keepalive not set
  Auto-duplex , Auto Speed , 100BaseTX/FX
  Last input never, output 00:04:34, output hang never
  Queueing strategy: fifo
  Output queue 0/40, 0 drops; input queue 0/75, 0 drops
     1 packets input, 64 bytes
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 0 multicast
     6 packets output, 802 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 lost carrier, 0 no carrier
Router#show interfaces ethernet0/0
Ethernet0/0 is up, line protocol is down
  Hardware is AmdP2, address is 0030.9491.2ac0 (bia 0030.9491.2ac0)
  Internet address is 192.168.1.1/24
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
     reliability 237/255, txload 1/255, rxload 1/255
  Keepalive set (10 sec)
  Last input never, output 00:00:07, output hang never
  Output queue :0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     10 packets output, 851 bytes, 0 underruns
     10 output errors, 0 collisions, 1 interface resets
     10 lost carrier, 0 no carrier
thanks for reply
i was using crossover cable so that was problem
