12-27-2016 09:03 PM - edited 03-08-2019 08:43 AM
Greeting,
I have configure NAT on my Cisco 2651XM series router OS 12.2(8r).
When I check the NAT table it only shows that UDP traffic is being routed nothing else.
Any Ideas ?
Solved! Go to Solution.
12-29-2016 11:47 AM
Hello
Try applying a default route!
ip route 0.0.0.0 0.0.0.0 fa0/0 192.168.13.x
res
paul
12-29-2016 06:41 AM
Why is Fa0/1 configured for half duplex?
12-29-2016 11:01 AM
so..it should not be it should be full duplex which I will correct.
I am starting to believe the problem is the router itself, every time the router is power cycled it comes back to the initial configuration mode as if it has never been setup before.
I execute the configuration and issue the copy run start and the same thing happens on next power cycle it goes into the initial configuration mode.
Any ideas, I have another identical router, I am going to set that one up and see if it has the same issues.
12-29-2016 11:47 AM
Hello
res
paul
12-30-2016 08:59 PM
I appreciate the help.
I just want to make sure that I understand what the problem was, since I am jumping to another router it was necessary to define the route to the next router which I had not done.
If I have this wrong please feel free to let me know.
Appreciate you assisting this new guy.
V/R
Paul
12-31-2016 01:36 AM
Hello
The rtr didn't have the information on where to route external packets too.
When you defined the static default with a nexthop addresss then any traffic originating from your "inside" network was able to be Natted and forwarded onto the next hop router
res
paul
