267
Beginner
Cisco 2801 Maximum HWICs
Dear Friends,
I have one C2801 Router with IOS 12.4(23), it has 2 onboard WAN ports, and 4 module slots
We need 6 more WAN ports, for this we are planning to install 3 x HWIC-2FE Modules.
But CISCO's official website says, Maximum Number of 2 Port HWICs allowed for the chassis C2891 is only 1
My question is can we add 3 x HWIC-2FE modules to the chassis?
Does it require any kind of license?
1 ACCEPTED SOLUTION
VIP Advisor
Please check this link, it provides detailed information.
http://www.cisco.com/c/en/us/td/docs/routers/access/2800/hardware/installation/guide/hw/01_hw.html
Table 2 Summary of Cisco 2800 Series Removable and Interchangeable Modules
Router Model
External Modules (In chassis slots)
Internal Modules
Network Modules
High-Speed WAN Interface Cards (HWICs)
Extension Voice Modules (EVMs)
Advanced Integration Modules (AIMs)
Packet Voice Data Modules (PVDMs) 1
Cisco 2801
2 single-wide (HWIC) or
2 double-wide (HWIC-D)
1 WIC/VWIC/VIC slot
1 VWIC/VIC (voice-only)
3 REPLIES 3
VIP Mentor
that's correct only 1 is allowed on a 2801 you need a more powerful router to support what your trying to do , its not a license issue is what the actual hardware is able to process , 1 card is the limit
That's a very old ios your running too
no you can physically add them but them actually running and doing anything no as the 2800 would be maxed out in hardware
Table 1.       Platform Support
Router Chassis
Maximum Number of 1 Port HWICs
Cisco 1921
Cisco 1941
Cisco 1941W
Cisco 2901
Cisco 2911
Cisco 2921
Cisco 2951
Cisco 3925
Cisco 3945
Cisco 3925E
Cisco 3945E
Cisco 1841
Cisco 2801
Cisco 2811
Cisco 2821
Cisco 2851
Cisco 3825
Cisco 3845
http://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/product_data_sheet0900aecd80581fe6.html
VIP Advisor
Router Model
Internal Modules
Network Modules
Cisco 2801
1 WIC/VWIC/VIC slot
Beginner
Thank you folks for the reply
Thank you folks for the reply,
The budget doesn't allow us to go for a powerful router,
All we can purchase is C2811, as the specs says, it supports 4xHWIC modules, unlike C2801 which supports only 2xHWICs
The question is, if we purchase the C2811 chassis, will it support 3xHWICs as on web-page
Table 1. Platform Support says, Maximum Number of 2 Port HWICs for C2811 = 1
That is confusing, please advise either it require some LICENSE to activate all 4 HWICs, or IOS upgrade, as available IOS is
(C2800NM-ADVENTERPRISEK9-M), Version 12.4(22)YB2
Content for Community-Ad
July's Community Spotlight Awards
