07-30-2013 07:57 AM - edited 03-07-2019 02:40 PM
Hello Folks!!
I'd like to know if the Cisco 2821 is hot-pluggable device, I want to plug a HWIC-2FE card in this device, is it possible without power down the router?.
Thanks in advance!!
Solved! Go to Solution.
07-30-2013 08:01 AM
07-30-2013 08:01 AM
No, that is not hot-swapable. You would need to turn it off.
07-30-2013 08:02 AM
Ok, thanks!!!
