12-17-2015 04:55 PM - edited 03-08-2019 03:08 AM
Hello, I'm new in the forum and new in the Cisco world too. I hope you can help me.
I will work with two C2901 in one station that comunicates with the other end using fiber (each one uses EHWIC-1GE-SFP-CU with a GLC-ZX-SM=
Mini GBIC).
I need one as the main unit and the other one as a back-up (stand-by) unit. What I'm trying to do is switch between the devices when the fiber links fails? What connections do I need to do, and how can I configure them?
Any idea will be helpful. Hope you can guide me in this
Thanks.
12-17-2015 07:53 PM
To clarify these 2901 are some distance from one another as you are using a GLC-ZX-SM SFP
so is one site a backup to the other, is there any other way they can communicate if the fibre fails?
12-18-2015 06:51 AM
Hello.
Yes, the distance between the two sites is 60 km. The only way to communicate both ends is fiber, but each fiber cable is independent from the other. The links reach the same site, but using different paths.
I hope I made my self clear
Thanks in advance
12-18-2015 01:09 PM
so two independent links using different paths, therefore very unlikely that both paths would go down at the same time.
I assume the Vlans go across the sites So I would use HSRP between the 2901s tracking the fibre links so then changing the gateway router as required.
12-18-2015 01:16 PM
Indeed, HSRP is what I am studying right now. I'll let you know if something comes up during the configuration. Thank you very much for your help Richard.
