Highlighted
Beginner
Cisco 2960 catalyst Crypto PKI certificate help
Good morning,
I have a number of switches from a customer that contain a crypro pki certificiate chain TP-self-signed, when running in Show runniing-config,
does the crypto key contain customer identifying information or network configuration, crypto keys have removed for security please see below
Switch#show ru
Building configuration...
Current configuration : 2937 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip subnet-zero
crypto pki trustpoint TP-self-signed-************
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-*************
revocation-check none
rsakeypair TP-self-signed-************
crypto pki certificate chain TP-self-signed-***************
certificate self-signed 01
  quit
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
no ip route-cache
shutdown
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
end
Switch#
1 ACCEPTED SOLUTION
Highlighted
Enthusiast
The self signed certs are generated internally by the switch to enable functions like SSH. They do contain the hostname and DNS domain that was set on the device when the cert was generated. If the DNS domain name is registered to the client and not just something made up, then it would be traceable.
1 REPLY 1
Highlighted
Enthusiast
Content for Community-Ad
