Cisco 2960 -LANBASEK9-M Switch
saroj pradhan
Hi ,
i have new to cisco 2960 -24TC-L  switch  and  want to configue  in CLI Mode  .when i connect the lan  to the switch  users in the network  disconnect from Internet.please help to configure it.
Saroj Pradhan
7 Replies 7
zac.quinn
Saroj,
I suggest you connect to the switch via the serial console port and configure it before you connect it to your LAN. You can then either run through the basic setup script or drop straight to the CLI and configure in detail without affecting your users.
Zac
I have configured the  switch  mgmt  VLAN an IP Address. Default GW ,name server ,ssh . Hope  it will work now.
But  I want  to know  the Difference  of 2960TC-L  and  2960PC-L  .
Saroj
PC-L has PoE ports the TC-L does not.
Zac
Out of the following  Cisco Catalyst 2960, 2960-C and 2960-S Series Switches  which one is a better option for LAN Switch,
Saroj
It depends what features you need.  See
http://www.cisco.com/en/US/products/ps6406/prod_models_comparison.html for a comparison of the various models.
Ok Thanks.
But what is the difference between Lan base and Lan Lite image.
Thnaks,
Saroj
If you go to the FAQs for the 2960 range -
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/prod_qas0900aecd80322c37.html
there is a lot of the info you are probably looking for but I've extracted a couple of sections for you
Q. What are the notable differences between the Cisco Catalyst 2960 LAN Base and LAN Lite switches?
A. Cisco Catalyst 2960 LAN Base switches have several advantages:
• Gigabit Ethernet connectivity in 8-, 24-, and 48-port configurations
• RPS support and support for a wide range of SFP transceivers
•  Enhanced security through Layer 2-4 access control lists (ACLs), DHCP  Snooping, and more extensive Network Admission Control capabilities such  as Web authentication and 802.1x enhancements
•  Additional QoS capabilities: The LAN Base IOS supports policing, class  and policy maps, differentiated services code point (DSCP), AutoQoS, and  configurable queue weights, buffers, and thresholds
• Higher network-level availability with features such as Flex Links and Link State Tracking
•  Increased number of VLANs (256) and other enhancements such as IPv6  Host, MLD Snooping, LLDP-MED, RSPAN, MVR, DHCP Option 82, and IP SLA  (responder)
Q. What are the similarities between the Cisco Catalyst 2960 LAN Base and LAN Lite switches?
A. Both Cisco Catalyst 2960 LAN Base and LAN Lite Switches support the following capabilities:
•  Scalable and highly secure network management: Secure Shell (SSH),  Secure Sockets Layer (SSL), Secure Copy Protocol (SCP), and SNMPv3  crypto
• Network management tool support by CiscoWorks, Cisco Network Assistant, and Catalyst Device Manager
• Baseline Network Admission Control and 802.1x MAC Auth Bypass and Protected Port
• Voice VLAN and voice-aware port security, BPDU Guard, and Root Guard
• Standard QoS with Class of Service (CoS) marking, Shaped Round Robin, Weighted Tail Drop, and Strict Priority scheduling
• Link aggregation using Port Aggregation Protocol (PAgP) and 802.3ad LACP
• Complete Spanning Tree Protocol support via 802.1s, 802.1w, and PVST+
• Multicast support in hardware with IGMP Snooping, Filtering, and Querier
• Troubleshooting and monitoring tools such as TDR, SPAN, and UDLD
Best regards,
Zac
