11-20-2012 05:34 AM - edited 03-07-2019 10:09 AM
Hello Everyone,
I'd like to know if is it possible to load lan base image on Cisco Switch 2960 TC-S.
This model (WS-C2960-48TC-S) come with lan lite image and it's the same (phisically) of the 2960 TC-L (lan base image).
If I try to upload the lan base image on flash of 2960 TC-S will works?? ..or the switch goes damaged?
Anyone do this before?
11-20-2012 10:06 AM
For example:
WS-C2960S-48LPS-L is LAN Base.
WS-C2960S-48TS-S is LAN Lite.
Refer:
Aru
*** Please rate if the post is useful ***
07-08-2016 07:24 PM
Thank you this was hard to find directly on Cisco main support site.
:D
11-20-2012 02:02 PM
Not possible. The appliance will "refuse" to boot the LAN Base IOS.
You cannot perform a software upgrade from a LAN-Lite to LAN Base appliance. You need to replace the entire unit.
