Atlas and Singlewire are blaming the 2960-X stating that it is blocking the multicast traffic and this is why the Atlas IPS-ZCM cannot register because the SLP packets are not reaching the Singlewire server.
Already worked with Cisco TAC and they state there are no issue on the 2960-X. But based on the wiresharks from both devices, I do see the SLP request leaving the Atlas device, but I never see it hit the Singlewire server. Both devices are physically on the same switch and on the same vlan.
I have enabled and disabled IP IGMP Snooping globally with no success.
Any suggestions on a fix would be appreciated.
Atlas devices is on port 1/0/43
Singlewire is a VM running on BE6K server on port 1/0/47
=====CONFIG-=====
version 15.0
no service pad
service password-encryption
hostname 2960
boot-start-marker
boot-end-marker
aaa new-model
aaa session-id common
clock timezone PST -8 0
clock summer-time PST recurring
switch 1 provision ws-c2960x-48ts-l
switch 2 provision ws-c2960x-24ts-l
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
no ip route-cache
interface GigabitEthernet1/0/1
switchport voice vlan 100
spanning-tree portfast
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
description **Connects to Paging Equipment**
switchport access vlan 100
interface GigabitEthernet1/0/44
description **Connects to Core Data Switch**
interface GigabitEthernet1/0/45
description **Connects to Fax Finder 440**
interface GigabitEthernet1/0/46
description **Connects to Point to Point Between INC & Plant A**
interface GigabitEthernet1/0/47
description **Connects to BE6K Server Port 1**
interface GigabitEthernet1/0/48
description **Connects to INCVGW-2921 Port GE 0/0**
switchport trunk allowed vlan 1,100
switchport mode trunk
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
interface GigabitEthernet2/0/18
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
interface GigabitEthernet2/0/24
interface GigabitEthernet2/0/25
interface GigabitEthernet2/0/26
interface GigabitEthernet2/0/27
interface GigabitEthernet2/0/28
interface Vlan1
description **DATA VLAN**
ip address 10.10.0.82 255.255.0.0
interface Vlan100
description **VOICE VLAN**
ip address 10.11.0.3 255.255.255.0
ip default-gateway 10.10.0.81
