06-03-2019 02:10 AM
I have a 2960G-48 Port Switch I am planning to use in my home network for various VLANs / etc...
Powering the Switch on, I have the Orange Syst Light and getting Fan Faulty and Abnormal System Temperature errors during Boot of the Switch as well as when checking show env fan / temperature.
Strange thing is that the only fan in the switch is running at what looks like normal / fast speed. I took the cover off the switch and booted it again, same loading process and same errors but I can see the fan running and feel ample air coming out of the fan exhaust in the back of the unit...
What could be my issue here? Could those errors be false positives? Is there something I can check / do to see if the errors are legit? Just find it strange that the fan is running but getting a faulty fan / abnormal temp error with the cover on and off....
06-03-2019 02:15 AM - edited 06-03-2019 02:17 AM
Upgrade the firmware.
The fan could be running in low RPM which can generate the error message.
06-03-2019 02:16 AM
06-03-2019 08:40 AM
Thanks, I will give the software a shot first....
The fan is running pretty fast, so I dont think the RPMs are the issue..
Is there a sensor in the switch somewhere that could be dirty / unhooked?
06-03-2019 02:19 AM
It is a 3-wire fan, so it could be a fault sensor in the fan unit.
If you have a (any) spare known working 3-wire fan you could temporarily connect it on the bench and see if IOS still reports the error.
If it does then like the others had said upgrade the IOS, if the error goes away, replace the fan with the correct unit.
cheers,
Seb.
06-04-2019 03:03 AM
Upgraded the iOS and still get the errors
Tried a random 3 wire fan I had and it did not spin at all when plugged into the switch
06-04-2019 04:19 AM
