03-06-2010 11:14 AM - edited 03-06-2019 10:01 AM
Hi everyone,
I've got a C2960PD-8TT-L that is supposed to be able to take PoE over it's 10/100/1000 port (which also bears the label 'PoE Input'). I'm trying to power it from a C3524-PWR-XL and it is not working. I've tried about everything at this point. It works fine with a 48v brick plugged into the AC input on the back but I can't get it to come up with PoE. I've tried the 3524 switch (which powers an Aironet and a 7960 phone just fine) and an external PoE injector with no success. If it's powered from the wall, the 3524 is showing it as ILP-Device unknown.
Is there some trick I'm missing here?
Thanks in advance for any help.
-Byron
03-07-2010 04:22 AM
Is CDP enabled on both switches?
03-07-2010 10:58 AM
Yes, CDP is enabled and they both show up:
c2960#sho cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID Local Intrfce Holdtme Capability Platform Port ID
c3524 Gig 0/1 157 T S WS-C3524- Fas 0/14
_____
c3524#sho cdp nei
c2960 Fas 0/14 133 S I WS-C2960PDGig 0/1
03-07-2010 04:54 AM
I suspect you may have a mismatch between the older pre-standard PoE implementation of the C3524-PWR-XL and the 802.3af PoE standard supported on the C2960PD-8TT-L.
Was the PoE injector you tried out 802.3af compliant?
03-07-2010 11:02 AM
Ok, that's interesting... Maybe not.
The power injector I tried was an old Aironet injector, AIR-PWRINJ3.There is no 802.3af compliance markings on it, so I'm guessing probably not.
If that's the case, is there a workaround?
Thanks again.
03-07-2010 10:31 PM
The AIR-PWRINJ3 is pretty old and I suspect it predates the standard. However I may have one in the office and if so I'll try it out on our C2960-PD-8TT-L later today to test if it works.
Also, according to http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/prod_qas0900aecd80322c37.html, "the Cisco Catalyst 2960PD-8TT-L can be powered by another PoE switch, a power adaptor or power injectors that support 802.3af, including AIR-PWRINJ4."
I'm afraid I know of some solutions to get pre-802.3af equipment to work with 802.3af PoE power sources, but not the other way round. Maybe someone else can help on that one?
