Cisco 2960S - Delayed communication
joshhboss
So honestly I’ve been using Cisco 2960s. That I’ve found on eBay for a good price and I love them for camera networks but I’ve also been using them for events.: and in these events they have wired connections to clover devices, now during the last two events they’ve mentioned some delayed printing on the network. All devices on the same vlan. I wrote it off as a clover thing at first but then I noticed while setting up my last camera network. Even after all the cameras were address. I would try and log into them one by one and notice that it did actually take a few attempts of getting to web GUI for the camera to open. I think tried pinging the cameras before opening the GUI and the same behavior. First few packets wouldn’t go right through.. is there something I’m doing wrong with these setups. Or are these switches just to old.
switch ports are always
sw access vl 100
ip dev track max 1
Nothing else.
17 Replies 17
balaji.bandi
post below output :
show version
show run
show sdm prefer
show sdm prefer default
BB
try and set the mac address table timeout to something different than the default 360 seconds (e.g. 86400 seconds/24 hours):
2960S#conf t
2960S(config)#mac-address-table aging-time 86400 vlan 100
Thank you so much for responding. I already applied the command to my switches on the job I’m working on now.. and going to see if I notice an improvement. I’ll jump back on later this evening
About the mac aging, i had a thought.. Im actually going into an event today that i was going to try this but it occurred to me that there are many access points there where they have hand helds. and they are moving around connecting to different access points to get on the vlan 100.. will this aging cause a mac flap that could shut down ports.?
joshhboss
@balaji.bandi Check it out..
it does feel like it is working a bit better with the commands for mac address aging 86400
OffleaseSw102#show version
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.0(2a)SE9, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon 21-Dec-15 02:41 by prod_rel_team
ROM: Bootstrap program is C2960S board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(55r)SE, RELEASE SOFTWARE (fc1)
OffleaseSw102 uptime is 21 hours, 21 minutes
System restarted at 17:52:43 EST Fri Mar 12 2021
System image file is "flash:/c2960s-universalk9-mz.150-2a.SE9/c2960s-universalk9-mz.150-2a.SE9.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-48LPS-L (PowerPC) processor (revision D0) with 131072K bytes of memory.
Processor board ID FOC1547Y4R3
Last reset from power-on
3 Virtual Ethernet interfaces
1 FastEthernet interface
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 0C:85:25:DC:30:00
Motherboard assembly number     : 73-11907-06
Power supply part number        : 341-0393-02
Motherboard serial number       : FOC154709BV
Power supply serial number      : DCA1544U0VC
Model revision number           : D0
Motherboard revision number     : A0
Model number                    : WS-C2960S-48LPS-L
Daughterboard assembly number   : 73-11933-04
Daughterboard serial number     : FOC154655YF
System serial number            : FOC1547Y4R3
Top Assembly Part Number        : 800-30937-02
Top Assembly Revision Number    : C0
Version ID                      : V02
CLEI Code Number                : COMGZ00ARB
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C2960S-48LPS-L  15.0(2a)SE9           C2960S-UNIVERSALK9-M
Configuration register is 0xF
OffleaseSw102# show sd
OffleaseSw102# show sdm ?
  prefer  Show current template configuration
OffleaseSw102# show sdm prefer
 The current template is "default" template.
 The selected template optimizes the resources in
 the switch to support this level of features for
 0 routed interfaces and 255 VLANs.
  number of unicast mac addresses:                  8K
  number of IPv4 IGMP groups + multicast routes:    0.25K
  number of IPv4 unicast routes:                    8.375k
    number of directly-connected IPv4 hosts:        8K
    number of indirect IPv4 routes:                 0.375k
  number of IPv6 multicast groups:                  0.25K
  number of IPv6 unicast routes:                    0.25K
    number of directly-connected IPv6 addresses:    0.25K
    number of indirect IPv6 unicast routes:         0
  number of IPv4 policy based routing aces:         0
  number of IPv4/MAC qos aces:                      0.375k
  number of IPv4/MAC security aces:                 0.375k
  number of IPv6 policy based routing aces:         0
  number of IPv6 qos aces:                          60
  number of IPv6 security aces:                     0.125k
OffleaseSw102# show sdm prefer de
OffleaseSw102# show sdm prefer default
 "default" template:
good to know...however: define 'a bit better'...
instant response from the cameras on my network (254) whenever i re initiate a connection. (open the web browsers login to the camera)  i thought it was odd when this client mention the delay when printing at the event. but i did notice a delay everytime i tried logging into the cameras.(different location different switch.. but same model)(i basically only use 2960s 48port)(i know a little older)... at first when i noticed it on the gui. i then tried pinging first before launching the camera window. and first 3 to 4 packets would not go through..
i also ran a ping test with 'pinginfoview' (pinged 20 cameras continuously) and notice i was dropping packets here and there. but so far my test is running with over 4000 pings and no drops..
i noticed as i was just checking connectivity to the cameras from the switch that with several of the first pings there is a 1000ms ping reply.. this is after the mac address aging to 86400.. Could this be the device responding poorly..? i mean after that.. the communication is incredible.. but its that initiation..
OffleaseSw102(config-if)#do ping 192.168.254.117
Sending 5, 100-byte ICMP Echos to 192.168.254.117, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/203/1007 ms
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/5 ms
OffleaseSw102(config-if)#do ping 192.168.254.110
Sending 5, 100-byte ICMP Echos to 192.168.254.110, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/202/1001 ms
Thank you again
joshhboss
@balaji.bandi and here is sh run
OffleaseSw102#sh run
Building configuration...
Current configuration : 14745 bytes
! Last configuration change at 11:52:09 EST Sat Mar 13 2021
! NVRAM config last updated at 11:31:14 EST Sat Mar 13 2021
version 15.0
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime show-timezone
hostname OffleaseSw102
boot-start-marker
boot-end-marker
enable secret 5 ksdjfoafmpweompwmegm
username admin password 0 aB123457
no aaa new-model
clock timezone EST -5 0
clock summer-time EST recurring
switch 1 provision ws-c2960s-48lps-l
ip domain-name www.sdasfadfs.com
ip device tracking
crypto pki trustpoint TP-self-signed-635187200
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-635187200
 revocation-check none
 rsakeypair TP-self-signed-635187200
crypto pki certificate chain TP-self-signed-635187200
 certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
        quit
spanning-tree mode pvst
vlan internal allocation policy ascending
lldp run
interface FastEthernet0
 no ip address
interface GigabitEthernet1/0/1
 switchport access vlan 254
 ip device tracking maximum 1
 power inline consumption 8000
 storm-control broadcast level 1.00
 storm-control multicast level 10.00
 storm-control action shutdown
 storm-control action trap
interface GigabitEthernet1/0/2
 switchport mode trunk
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
 switchport trunk native vlan 254
 ip device tracking maximum 10
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
 spanning-tree portfast
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
 description LTS-Switch
interface GigabitEthernet1/0/52
interface Vlan1
 no ip address
interface Vlan200
 ip address 192.168.200.102 255.255.255.0
interface Vlan254
 ip address 192.168.254.3 255.255.255.0
ip default-gateway 192.168.200.1
ip http server
ip http secure-server
line con 0
line vty 0 4
 password XXXXXXXXX7
 login local
 transport input ssh
line vty 5 15
 login
ntp server 192.168.200.1
mac address-table aging-time 86400 vlan 254
end
OffleaseSw102#$
Hello
TBH you mention events but what is that in relation too?
Then you mention delay in printing -
FYI printers can go to “sleep” if they are not used and most drivers have a sleep mode timer that can be disabled or extended if this is what you are relating to in your OP regards events?
You could also make sure all access ports have spanning-tree portfast applied -
I would say that would tweaking the the cam table ageing for the whole vlan for 24 hrs just for printers going into sleep mode isn’t appropriate try disabling IPDT instead and implement the above suggestion then test again.
Kind Regards
Paul
Im sorry, I did mention in my original post that they were clover devices not specifying what they are. They are like POS devices. Tablets and Printers both made by a company called Clover. issue they had was a delay printing the drink or food order from tablet to kitchen or bar printers.
Hello
Have you tested with stp portfast enabled and with IPDT turned off?
Also why specifically apply the power consumption, Would suggest first let the devices auto negotiate its power with the switch then when you have a stable connection manually tweak
Kind Regards
Paul
i did start using stp portfast. and ive found that ipdt has been very helpful, i actually use it all the time, is it not recommended? i just into the habit of the power consumption because a few times when i had 48 ports (2960s - 370Watt) for some camera networks.. and when id go over the 24 ports the 25th camera and on would not work. so i learned about the power consumption and i was able to set it up to use all ports. ever since i just do it.. also not recommended?
and at the event now id like to add. the astro turf that they are using is causing static electricity all over the place.. im getting shocked like crazy to everything around me.. the switch is not on the astro turf but alot of the cables are running on them to the bars (where the clover tablets and printers are)
Hello
What i suggested was for trouble shooting your problem it wasn’t meant to be a permanent solution I would like to say though using features just because they have worked in the past isnt recommended
Regards ipdt unless you have statically ip assigned end hosts then i don’t think it would be applicable to you here as by default dynamic arp inspection (DAI) is also enabled with ipdt so ipdt would be used only against arp that dai is able to check unless that is you have dhcp snooping enabled for dhcp end hosts.
Again the power consumption was only a suggestion so if you know the exact pw requirements for your poe devices then all good however if the switch fails after a certain amount of poe devices are attached when power is auto negotiated and it doesn’t do it when you manually set it then it could be either a good or bad sign as it may indicate the hosts are not being supplied enough power or that your switch supply isnt adequate for those poe hosts.
Stp portfast negates each port going through the stp process before it’s allowed to forward traffic plus negates stp transition whenever  the port goes up/down
So all the above as ive stated is just a suggested approach to TS your problem.
Lastly I’m no electrician but static electricity around network devices and peripherals isn’t really a good idea!
Kind Regards
Paul
