Cisco 2960S(LanLite) Port Aggregation to 2 (Cisco SMB 300 Series Switches)
levi.rogers
Beginner
Beginner
I am currently trying to setup my new cisco switches.
What I am trying to do:
I have 2 SMB 300's which are "access" switches.  Essentially the drops come down into these switches.  I also have a backbone switch which sets in my server racks.  In order to ensure maximum capacity between the backbone switch and the access switches I wanted to use Port Aggregation.  8 ports from each access switch make each trunk going to the backbone switch.  I can link the two access switches together and everything works fine, however, when I hookup the backbone switch I see a large amount of packet loss, dropped connections etc.
About me:
Just really brief to give you an idea of what you are dealing with, I am very new to cisco.  I am not a complete dolt but some of the innerworkings of the Cisco IOS through me for a loop.  Any help on this matter would be greatly appreciated.
Included:
A copy of the 2960 config, and a copy of one of the 300 configs.
2960 Config:
COREKNYNOR_001#show config
Using 3864 out of 524288 bytes
version 12.2
no service pad
service password-encryption
hostname COREKNYNOR_001
boot-start-marker
boot-end-marker
enable secret 5 $1$o6oi$SJIPCEVG3z4SSeTE.9n01/
no aaa new-model
clock timezone UTC -6
clock summer-time UTC recurring
authentication mac-move permit
ip subnet-zero
crypto pki trustpoint TP-self-signed-2877403904
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2877403904
revocation-check none
rsakeypair TP-self-signed-2877403904
crypto pki certificate chain TP-self-signed-2877403904
certificate self-signed 01 nvram:IOS-Self-Sig#3434.cer
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
interface Port-channel1
interface Port-channel2
interface FastEthernet0
no ip address
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
description trunkAcc2
channel-group 1 mode desirable
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
description trunkAcc1
channel-group 2 mode desirable
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
interface GigabitEthernet0/48
interface GigabitEthernet0/49
interface GigabitEthernet0/50
interface Vlan1
ip address 192.168.xxx.xxx 255.255.xxx.xxx
ip default-gateway 192.168.xxx.xxx
ip http server
ip http secure-server
banner login ^C Access for authorized users only.  Please enter your username and password. ^C
banner motd ^C  Please contact Admin for questions regarding the setup of this switch. ^C
line con 0
line vty 0 4
password 7 034C1142321A314342084C5756584A
login
line vty 5 15
password 7 145F584238113A2428296667635946
login
end
300 Config:
interface port-channel 1
description CORE_TRUNK_2
exit
interface range ethernet g(41-48)
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
channel-group 1 mode on
exit
interface vlan 1
exit
interface vlan 1
no ip address dhcp
exit
bonjour service enable csco-sb
bonjour service enable http
bonjour service enable https
bonjour service enable ssh
bonjour service enable telnet
hostname ACCESS2KNYNOR
username cisco password cc8d1b658aa0970b3ca367cdb7ccd7a858b6851c level 15 encrypted
no snmp-server enable
snmp-server location KRNY_NOR
snmp-server contact "ADMIN"
clock timezone -6
clock summer-time recurring usa
I feel like I might have something set wrong on one side or the other with what type of etherchannel it is looking for and the mode that it is set in.  Any help on this matter would be greatly appreciated, also if you could give a little direction on the appropriate commands to make any necessary changes I wouldn't dislike you by any means.
Cheers!
glen.grant
Advisor
Advisor
  You have the channel settings incorrect .  On one switch you have them set as desirable and on the other it is forced "on" .  This won't work . Both sides have to match.  Not knowing what the "300" is capable of you should just force both sides as on .  The 2960 should not be desirable if the other switch does not have the capability of negotiating the etherchannel. Make the 2960 channel-group X mode on also .   That is also the issue with forcing channels on if both sides are not exactly the same  and in your config they are not you can blackhole the traffic and cause all sorts of issues.
glen.grant
Advisor
Advisor
