Showing results forĀ
Search instead forĀ
Did you mean:Ā
cisco 2960s probelem
luodaheng
my topology is  Cisco6509(vss)-----trunk------2960s
the core switch are running VSS and have double link to access switch 2960s, and the all layer 2 inerface (user gateway) are configured on 6509
and the 2960s has user vlan 195 ,and managment vlan 226,
the problem is before this problem ,they have runnning well more than 6 month
pc connect to some ports of vlan 195 can not ping server belonged to other vlan, even can not ping the gateway(6509),
when this problem happened, pc belong to vlan 195 can ping other pc which belong to
different switch but in same vlan
this problem we have meet 2 times,every time we restart the switch ,it go normall..
could you tell me ?what is the root caused?
7 Replies 7
Dragan Ilic
Level 4
Level 4
Could you share some config for this? VSS switches especially?
HTH,
Dragan
HTH,
Dragan
thanks! we have more 100 switch ,all are working well
this prolbem we are meet 2 times in this network
C2960s configuration:
interface GigabitEthernet1/0/32       //this interface connect to desktop
switchport access vlan 195
switchport mode access
switchport voice vlan 373
switchport port-security maximum 2
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
storm-control broadcast level pps 50 1
spanning-tree portfast
spanning-tree bpduguard enable
interface GigabitEthernet1/0/49  //this connect to vss-6509-1
description  c6509_G11/1/1
switchport trunk native vlan 226
switchport mode trunk
udld port
channel-group 1 mode desirable
interface GigabitEthernet1/0/50      //this connect to vss-6509-2
description  c6509_G12/1/1
udld port
spanning-tree guard loop
interface Port-channel1
description SZCW01
configuration in vss 6509
interface GigabitEthernet1/3/18
description C2960s_gi1/0/49
switchport
channel-group 28 mode desirable
interface GigabitEthernet2/3/18
description C2960s_gi1/0/50
switchport
interface Port-channel28
description SZAW18
switchport
Config is fine...I see you didn't configured UDLD on ports on 6500s - why?
Do you see something interesting in logs of switches when there is outage?
HTH,
Dragan
HTH,
Dragan
UDLD on 6500 VSS  not configuration,this is not problem with this issue.
and no  any log in 2960s  and 6500 vss
when we meet the problem ,i still can remote management the switch ,this mean the switch and UPLINK fiber are working.
and also ,when the problem are happening ,the same vlan in other 2960s are also working well.
Parvesh Paliwal
Level 3
Level 3
As you are able to get to the machine within the same VLANs, it is purely an issue with routing.
please post the outputs :
sho ip route
sho vlans
sho access-lists
Parvesh
luodaheng
routing and vlan195 is well , i sure
because this in many switch have it ,the host of this vlan in ohter switch work well and can go anywhere, only 1 switch have  the problem
i have more than 10  2960s hvae that vlan,only the desktop connet to this2960s have problem,same vlan desktop on other switch still working well
