04-05-2018 12:12 AM - edited 03-08-2019 02:32 PM
I have just upgraded my 2960x switch IOS to 15.2(2r)E2 version. Everything is running fine except the light on the console port is in up state(green light on) although there is no console cable plugged in.
Is this some IOS bug or any other issue?
Kindly suggest if someone else is facing the same issue.
Thank you.
04-05-2018 12:26 AM
04-05-2018 02:09 AM
Thank you but it was not the case with previous IOS version. If this is normal then it should have been lit with the previous IOS as well. Why it changed its status with this upgrade.
04-05-2018 02:10 AM
Is it USB console or Rj45?
Deepak Kumar
04-05-2018 02:11 AM
Its RJ45.
04-12-2018 01:49 AM
I am still looking for an answer. Do you know something that can help? Thank you.
