cisco 2960x switch renumber
carters
How do i renumber a switch ie   when there is an existing switch 3 in the stack?  Do i have to un-provision switch 3 and 4 and reconfigure ?
I tried the following below and rebooted but it did not work.
conf t
switch 4 renumber 3
exit
reload
Julio E. Moisa
(config)#switch 1 renumber ?
<1-8> New switch number
Yes that is the way to renumber a switch and reboot it to take effect.
Have you tried this command first to remove the provisioned switch:
no switch <number> provision
and also:
reload slot <slot id>
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
I am going to try this on May 3rd after hours.
thanks
rick
you have to renumber the exisiting switch 3 to a different number like say 5 then renumber 4 to 3 then then "5" to 4 you cannot renumber a switch to an existing switch number.
mhumphries73
you have to renumber the existing switch 3 to a different number like say 5 then renumber 4 to 3 then then "5" to 4 you cannot renumber a switch to an existing switch number.
