11-19-2017 02:12 AM - edited 03-08-2019 12:47 PM
I just ordered 2 new Cisco Catalyst 2960x ( WS-C2960X-48FPS-L) recently, but i havent received it from IT Vendor. These 2 switches will be using the flexstack cable to acts as one switch. I would like to know whether is this model (WS-C2960X-48FPS-L) able to do IP static routing and inter vlan routing? If there any limitations for QOS ?
Thank you for your help.
11-19-2017 03:40 AM - edited 11-19-2017 03:44 AM
Hello
Datasheet seems to suggest it does support static,inter-vlan routing, and QOS - here
res
Paul
11-19-2017 03:51 AM
Paul
Thanks for your respond. This is a new switch. Do I need to configure the Switch SDM template by issue a command #sdm prefer lanbase-routing? As I know those old model Cisco 2960s need to enable the lanbase routing. Hope to hearing from you again
Tks
11-19-2017 09:10 AM
Yes, you can use the device for IP-routing after changing the SDM template. The biggest limitation is that only 16 static routes can be configured.
