cisco 3524xL ,switchport voice vlan
sarahr202
Contributor
Contributor
Hi everybody.
I have encountered a different issue. When I configure " switchport voice vlan 2" under f0/2 connected to ip phone, it does not have any effect.
Below is my set up:
Sw  is cisco cat 3524 XL.
ip phone-------f0/2( vlan1)-----SW----f0/1---trunk------f0/0-CME-router+dhcp
                                                       f0/3( vlan2)
                                                       tftp server ( 201.201.201.3)
switch has two vlans:
vlan1 (data)   200.200.200.0/24
vlan 2 (voice)  201.201.201.0/24
Switch management int vlan 1 : 200.200.200.3
router
f0/0.1  200.200.200.1
f0/0.2  201.201.201.1
The trunk is working correctly.
Sw can ping 200.200.200.1 as show below:
Switch#ping 200.200.200.1
Sending 5, 100-byte ICMP Echos to 200.200.200.1, timeout is 2 seconds:
Tftp can ping 201.201.201.1 as shown below:
C:\Users\Administrator>ping 201.201.201.1
Pinging 201.201.201.1 with 32 bytes of data:
Reply from 201.201.201.1: bytes=32 time=1ms TTL=255
The problem is when I configured " switchport voice vlan 2" under f0/2, it does not work i.e  I dont see any stp instance for vlan 2 as shown below:
Switch(config)#int f0/2
Switch(config-if)#switchport voice vlan 2
Switch#show spanning-tree int f0/2
Interface Fa0/2 (port 14) in Spanning tree 1 is FORWARDING
   Port path cost 19, Port priority 128
   Designated root has priority 32768, address 0006.2818.0100
   Designated bridge has priority 32768, address 0006.2818.0100
   Designated port is 14, path cost 0
   Timers: message age 0, forward delay 0, hold 0
   BPDU: sent 1076, received 0
Below I have listed different output from the switch :
Switch#show vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/2, Fa0/4, Fa0/5, Fa0/6,
                                                Fa0/7, Fa0/8, Fa0/9, Fa0/10,
                                                Fa0/11, Fa0/12, Fa0/13, Fa0/14,
                                                Fa0/15, Fa0/16, Fa0/17, Fa0/18,
                                                Fa0/19, Fa0/20, Fa0/21, Fa0/22,
                                                Fa0/23, Fa0/24, Gi0/1, Gi0/2
2    voice                            active    Fa0/3
Switch#show running-config
Building configuration...
Current configuration:
version 12.0
interface FastEthernet0/1
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 2
interface VLAN1
ip address 200.200.200.2 255.255.255.0
no ip directed-broadcast
no ip route-cache
interface VLAN2
no ip route-cache
shutdown
thanks and have a great day
I think I found out solution of your problem try this:
int f0/2
switchport priority extend cos 0
spanning-tree portfast
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_wc5/swg/swports.html#wp1029161
Please rate helpful post.
Best regards,
Abzal
7 Replies 7
Abzal
Rising star
Rising star
Try this:
int f0/2
Switchport mode access
Switchport voice vlan 2
Spanning-tree portfast
Int vlan 2
No shutdown
Please rate helpful posts.
Best regards,
Abzal
Thanks Abzal
I already tried that . It did not work.  When i configured f0/2 as trunk, it works.
Hi Sarah,
The 3524 is not a POE switch and so it doesn't support the voice vlan.
Reza
Hi Reza.
The switch iam using 3524 xl has poe. Infact my 7940 ip phone is plugged in and all powered up.
thanks
int f0/2
Best regards,
Abzal
Hi Abzal.
That exactly I did to make it work.
thanks
Hi Sarah,
I apologize.  I wasn't aware that the 3524-XL support POE.
Sorry
Reza
Recognize Your Peers
