Cisco 3550 for home lab, not getting to command prompt
jmiller277
I'm setting up a home lab and bought a 3550 to use as a console server. It is not getting me a command line, but shows the following output and no more:
System Bootstrap, Version 11.0(10c), SOFTWARE
Copyright (c) 1986-1996 by cisco Systems
I don't have any devices hooked up to it yet. I can get command line from a switch using the same cable.
Any ideas are appreciated.
Damien Madison
It looks like you do not have a image to load from on the flash. If you can get to the flash card try putting a image file from cisco on it and power it down and back up.
