Cisco 3560 48 port with IOS DENALI 16.3.6
jorge75medina
Need help, I have several 3560 48 port switches that hangs and locks when adding a new VLAN. I can reconnect via SSH but it hangs as well when issuing any command, including any SHOW commands. I run DENALI IOS version 16.3.6 on it. I believe it is a bug with the IOS. Please help
11 Replies 11
marce1000
 - Issue show logging after this is tried; check if you have any errors or additional info being logged.  Besides that , what is your global intranet vlan setup. Do you have a central vtp server, are you adding a vlan on the  correct switch, etc....
 M.
Nothing but normal syslog messages, we dont use VTP and have the switch on transparent mode. Yes I am adding a vlan on the  correct switch.
Post the complete output to the command "sh proc cpu sort | ex 0.00".
I will, what is purpose of the command, and what will it tell us?
CPU utilization for five seconds: 22%/7%; one minute: 25%; five minutes: 24%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
508 2810612 4941429 568 4.24% 4.42% 4.47% 0 SISF Switcher Th
509 2393282 6427602 372 3.12% 3.71% 3.70% 0 SISF Main Thread
232 1139040 4139965 275 1.59% 1.61% 1.59% 0 Spanning Tree
505 939514 198591 4730 1.04% 1.45% 1.35% 0 SNMP Traps
53 698464 2694653 259 0.95% 1.13% 1.10% 0 ARP Snoop
118 453542 5244512 86 0.71% 0.70% 0.69% 0 IOSXE-RP Punt Se
224 489764 198133 2471 0.63% 0.76% 0.70% 0 MAC Notification
74 144065 525847 273 0.31% 0.20% 0.19% 0 IOSD ipc task
288 173079 2685414 64 0.23% 0.29% 0.27% 0 DAI Packet Proce
155 54699 93195 586 0.15% 0.10% 0.08% 0 MATM RP Shim Pro
342 381 77 4948 0.15% 0.50% 0.11% 2 SSH Process
207 82782 2121293 39 0.15% 0.09% 0.09% 0 IP ARP Retry Age
196 23544 31456 748 0.07% 0.03% 0.02% 0 CDP Protocol
306 90603 315537 287 0.07% 0.14% 0.12% 0 IP SNMP
99 56318 83670 673 0.07% 0.07% 0.07% 0 NGWC Learning Pr
204 89699 2121297 42 0.07% 0.12% 0.12% 0 IPAM Manager
208 39583 247959 159 0.07% 0.05% 0.07% 0 IP Input
35 93723 459590 203 0.07% 0.13% 0.13% 0 ARP Input
136 37624 87921 427 0.07% 0.04% 0.06% 0 PLFM-MGR IPC pro
CPU looks good. This is most likely a bug in the version you are running. Open a ticket with TAC, as there maybe other reports of the same issue. They will likely ask you to upgrade or downgrade.
Thank you!!!
SISF?
Is IPv6 enabled?
It is not.
reading the exact release notes below there is not specific matching or fixed bugs but similar hang bugs , i use 16.3.7 on my 36s and its stable , same train and package so its an easy enough upgrade , shouldn't be any micro code or boot loader change
Release notes for 16.3.7 3650/3850
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-3/release_notes/ol-16-3-3850.html
if you dont have TAC support the cli analyzer may show the bug id as another option , if not just upgrade.
