07-13-2011 11:18 AM - edited 03-07-2019 01:12 AM
i have a Cisco 3560E switch, i actually upgraded the IOS in the switch and after reloading the switch is not coming up , its just stuck at a point shown below and the fan noise is so loud..i tried booting it with old image but still the same issue..can any one help me with any suggestions
extracting ucode_info (77 bytes)
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: SF ASIC BIST : Begin
POST: SF ASIC BIST : End, Status Passed
POST: Switch Fabric Memory Tests : Begin
POST: Switch Fabric Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: Inline Power Controller Tests : Begin
POST: Thermal, Fan Tests : Begin
this were its stuck
07-13-2011 11:39 AM
Have a look at this doc for troubleshooting and recovery:
07-13-2011 03:13 PM
Downgrade your IOS. The 3560E has a USB port at the back for you to plug a specially-formated USB (FAT16) with the BIN file. Break the bootup and force the 3560E to go into ROMmon and boot the USB stick using the command "boot usbflash0:IOS_filename.bin".
07-13-2011 05:11 PM
Not sure from which IOS you upgraded your switch. If you have upgraded from post 12.2(50) to any of the latest IOS images, there is a firmware/microcode upgrade in them. Usually it takes about 5 min for a standalone switch to boot (First time). During this time, its normal for Fans to spin at maximum rpm.
AJ.
07-13-2011 09:03 PM
It didn't specify in the opening thread of "Upgrading microcode ...".
07-14-2011 12:07 PM
yes i am upgrading from 12.2(35 to 12.2 (58)..and i saw the microcode updates but here was it failed and it stopped doing the upgrade..moreover the fan is spinning at maximum RPM..i tried to downgrade the IOS but it is not working it just stuch here and there...can you let me know how to do a factory default..
07-14-2011 03:12 PM
Factory default will only reset your password. So this is not going to help you.
