Cisco 3560 PS POE switch
dondubuque
Here is what is in the flash;
85361 drwx 4096 .
2 drwx 4096 ..
85362 -rw- 2097152 nvram_config
85363 -rw- 2097152 nvram_config_bkup
85364 -rw- 15950464 cat3k_caa-guestshell.16.03.06.SPA.pkg
85365 -rw- 22302593 cat3k_caa-rpbase.16.03.06.SPA.pkg
85366 -rw- 265124472 cat3k_caa-rpcore.16.03.06.SPA.pkg
85367 -rw- 9095808 cat3k_caa-srdriver.16.03.06.SPA.pkg
85368 -rw- 211675764 cat3k_caa-wcm.16.03.06.SPA.pkg
85369 -rw- 13423228 cat3k_caa-webui.16.03.06.SPA.pkg
85370 -rw- 4737 packages.conf
85371 -rw- 1258 bootloader_evt_handle.log
85372 drwx 4096 core
23281 drwx 4096 .prst_sync
38801 drwx 4096 .rollback_timer
46562 drwx 4096 dc_profile_dir
46564 drwx 4096 gs_script
85373 -rw- 65301 memleak.tcl
85374 drwx 4096 .installer
1078792192 bytes available (571293696 bytes used)
switch: ?
? -- Present list of available commands
arp -- Show arp table or arp-resolve an address
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
emergency-install -- Initiate Disaster Recovery
flash_init -- Initialize filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
mgmt_init -- initialize management port
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
ping -- Send ICMP ECHO_REQUEST packets to a network host
readrtc -- Read RTC
rename -- Rename a file
reset -- Reset the system
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
set_bs -- Set attributes on a boot sector filesystem
set_param -- Set system parameters in flash
type -- Concatenate (type) file(s)
unset -- Unset one or more environment variables
version -- Display boot loader version
writertc -- Write RTC
As you can see you can't reset anything.  No erase.  I need to return this switch to the defaults as it will not boot.  When you boot it goes into a loop and keeps rebooting.
I think that if I could bring the switch back to factory settings I may able to save it.
5 Replies 5
Leo Laohoo
Post the complete output to the ROMMON command of "set".
dondubuque
ABNORMAL_RESET_COUNT=0
ASIC_PCI_RESET=1
AUTOREBOOT_RESTORE=1
BOOT=flash:packages.conf
BOOT_LOADER_UPGRADE_DISABLE=1
BSI=0
CFG_MODEL_NUM=WS-C3650-24PS-S
CLEI_CODE_NUMBER=INM2N00ARA
CSR_PCIERST_DISCONNECTED=yes
DEFAULT_ROUTER=10.10.10.1
D_STACK_DOMAIN_NUM=1
ECI_CODE_NUMBER=471211
IP_ADDR=192.0.2.123/255.255.255.0
LICENSE_BOOT_LEVEL=ipbasek9,all:ngwc;
MAC_ADDR=A4:53:0E:5D:4F:80
MANUAL_BOOT=yes
MODEL_REVISION_NUM=Q0
MOTHERBOARD_ASSEMBLY_NUM=73-15899-07
MOTHERBOARD_REVISION_NUM=A0
MOTHERBOARD_SERIAL_NUM=FDO232616SA
POE1_ASSEMBLY_NUM=73-16439-02
POE1_REVISION_NUM=A0
POE1_SERIAL_NUM=FDO23260AV2
RANDOM_NUM=1839200236
RECOVERY_BUNDLE=sda9:cat3k_caa-recovery.bin
SWITCH_NUMBER=1
SYSTEM_SERIAL_NUM=FDO2326F1P8
TAN_NUM=800-41244-04
TAN_REVISION_NUMBER=D0
TEMPLATE=advanced
TERMLINES=0
VERSION_ID=V05
In ROMMON, do this:  set MANUAL_BOOT no
And then reboot the switch.
How would I gain access to ROMMON?
Interface GE 0 link down***ERROR: PHY link is down
The system is not configured to boot automatically. The
following command will finish loading the operating system
software:
boot
