Cisco 3650 High CPU utilization by TPS IPC Process
ShwedOleg
Hi All
Help me
Switch Model              SW Version                 SW Image                          Mode
WS-C3650-24TS             16.6.1            CAT3K_CAA-UNIVERSALK9      INSTALL
#show processes cpu sorted 5sec | exclude 0.00
CPU utilization for five seconds: 93%/3%; one minute: 92%; five minutes: 92%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
 357    93364486     8721333      10705 85.44% 85.10% 85.57%   0 TPS IPC Process
 120     1721823     9546320        180  1.04%  0.87%  0.74%   0 IOSXE-RP Punt Se
  37     8288518     4942295       1677  0.80%  0.90%  0.90%   0 ARP Input
 278      977611     2907172        336  0.72%  0.55%  0.49%   0 HTTP CORE
 233     2503819     9046564        276  0.40%  0.29%  0.27%   0 Spanning Tree
  74     1067446     4208502        253  0.40%  0.20%  0.18%   0 IOSD ipc task
 359      908837    13256583         68  0.16%  0.09%  0.08%   0 MMA DP TIMER
 209      974333     3373875        288  0.16%  0.17%  0.16%   0 IP Input
 208     1078093    25957544         41  0.16%  0.10%  0.08%   0 IP ARP Retry Age
 514      818536     5112437        160  0.08%  0.08%  0.08%   0 EIGRP-IPv4 Hello
 328      906627    13256609         68  0.08%  0.08%  0.08%   0 MMA DB TIMER
 268       64185      584948        109  0.08%  0.08%  0.08%   0 TCP Timer
 113      384724     8518546         45  0.08%  0.04%  0.03%   0 100ms check
 205     1157498    25957568         44  0.08%  0.10%  0.09%   0 IPAM Manager
 138      283503      212970       1331  0.08%  0.03%  0.02%   0 FEP backgroundp
  59       92199      722273        127  0.08%  0.08%  0.08%   0 crypto sw pk pro
What is this TPS IPC process?  Why such a high CPU utilization?
ShwedOleg
Really nobody knows what is this TPS IPC process? Why such a high CPU utilization?
Spoiler
TPS in ‘TPS IPC Process’ stands for ‘Trust Point Security’. This process works very closely with SMD Session manager daemon. Together these do help service the authentication and session management routines. It's related to AAA services.
