Cisco 3650 IOS XE 3.6.0 - LLDP is not working correctly
mlinder01
Beginner
Beginner
Dear All,
We have a very strange issue with the new release for the Cisco 3650/3850 Switches IOS XE 3.6.0.
Setup:
- Cisco 3650 48 Port PoE Switch with Nortel/Snom Phones attached
with IOS XE 3.3.0
- Everything is working correctly the phones get their Voice-VLAN etc.
with IOS XE 3.6.0
- LLDP is not working correctly the phone get the message "No LLDPDU's received"
but if on IOS XE 3.6.0 the debug command "debug lldp states" is active everything is working...
I found nothing in the Web and in the Bug-Toolkit...
Many thanks for any help,
Manuel
5 Replies 5
Reza Sharifi
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Did you enable LLDP?
Hi Reza,
Thanks for your reply...yes lldp is enabled...and so far we did:
- Reapply voice-vlan configuration
- Disable/Enable LLDP
- Reboot the Switch
- Reset the Phones
... and only if we do "debug lldp" then it is working...strange
This coulld bug in the OS you are running specially since the product is so new.  Open a ticket with TAC so they can help in resolving the issue.
Thanks Reza...
Does anybody with a Cisco 3650/3850 Switch also see this Bug in Version 3.6.X?
Manuel
Richard Primm
Hey Manuel,
This definitely needs to be investigated.  Please open a tac case and we can dig into this for you.
 -LP
Recognize Your Peers
