10-25-2010 04:06 AM - edited 03-06-2019 01:43 PM
Hi out there
We have a Cisco 3750 running C3750 Software (C3750-IPBASE-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1). We have a lot of voice traffice passing through this switch and through sniffing we can see that it is dropping a lots of RTP packets. It is pretty basic configured - no QoS etc defined, no DSCP, WRED etc
We have been looking on the interfaces:
#sh int gi 1/0/7
GigabitEthernet1/0/7 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 001b.2b3e.a807 (bia 001b.2b3e.a807)
Description: CVN002
MTU 9000 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 10/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:17, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 4370000 bits/sec, 4867 packets/sec
5 minute output rate 41241000 bits/sec, 7080 packets/sec
230819752 packets input, 3991716436 bytes, 0 no buffer
Received 250283 broadcasts (0 multicast)
0 watchdog, 250249 multicast, 0 pause input
340046289 packets output, 2013348553 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
I cannot see any drops there but if I look at the buffers I can see a huge number of missed on a que named RxQ8 and RxQ15
h buffers
Buffer elements:
477 in free list (500 max allowed)
218948661 hits, 0 misses, 0 created
Public buffer pools:
Small buffers, 104 bytes (total 50, permanent 50, peak 179 @ 3d15h):
48 in free list (20 min, 150 max allowed)
109160983 hits, 43 misses, 129 trims, 129 created
0 failures (0 no memory)
Middle buffers, 600 bytes (total 25, permanent 25, peak 49 @ 3d15h):
24 in free list (10 min, 150 max allowed)
6127 hits, 12 misses, 36 trims, 36 created
Big buffers, 1536 bytes (total 50, permanent 50):
36 in free list (5 min, 150 max allowed)
985982 hits, 0 misses, 0 trims, 0 created
VeryBig buffers, 4520 bytes (total 25, permanent 10, peak 26 @ 3d15h):
10 in free list (0 min, 100 max allowed)
234 hits, 8 misses, 1 trims, 16 created
Large buffers, 5024 bytes (total 0, permanent 0):
0 in free list (0 min, 10 max allowed)
0 hits, 0 misses, 0 trims, 0 created
Huge buffers, 18024 bytes (total 4, permanent 0, peak 8 @ 3d15h):
4 in free list (0 min, 4 max allowed)
132230 hits, 4972 misses, 9915 trims, 9919 created
Interface buffer pools:
RxQFB buffers, 2040 bytes (total 904, permanent 904):
898 in free list (0 min, 904 max allowed)
396191 hits, 0 misses
RxQ0 buffers, 2040 bytes (total 1200, permanent 1200):
700 in free list (0 min, 1200 max allowed)
885730 hits, 0 misses
RxQ1 buffers, 2040 bytes (total 128, permanent 128):
2 in free list (0 min, 128 max allowed)
1251686 hits, 13950 fallbacks
RxQ2 buffers, 2040 bytes (total 64, permanent 64):
0 in free list (0 min, 64 max allowed)
64 hits, 0 misses, 0 trims, 0 created
RxQ3 buffers, 2040 bytes (total 128, permanent 128):
13997270 hits, 176747 fallbacks
RxQ4 buffers, 2040 bytes (total 128, permanent 128):
1 in free list (0 min, 128 max allowed)
137428 hits, 1653 fallbacks
RxQ5 buffers, 2040 bytes (total 96, permanent 96):
32 in free list (0 min, 96 max allowed)
64 hits, 0 misses
RxQ6 buffers, 2040 bytes (total 128, permanent 128):
0 in free list (0 min, 128 max allowed)
131 hits, 3 misses
RxQ7 buffers, 2040 bytes (total 192, permanent 192):
59 in free list (0 min, 192 max allowed)
170653 hits, 0 misses
RxQ8 buffers, 2040 bytes (total 64, permanent 64):
1102458 hits, 1020513 misses
RxQ9 buffers, 2040 bytes (total 1, permanent 1):
0 in free list (0 min, 1 max allowed)
1 hits, 0 misses
RxQ10 buffers, 2040 bytes (total 64, permanent 64):
1 in free list (0 min, 64 max allowed)
13045721 hits, 203843 fallbacks
RxQ11 buffers, 2040 bytes (total 16, permanent 16):
0 in free list (0 min, 16 max allowed)
16 hits, 0 misses
RxQ12 buffers, 2040 bytes (total 96, permanent 96):
0 in free list (0 min, 96 max allowed)
96 hits, 0 misses
RxQ13 buffers, 2040 bytes (total 16, permanent 16):
16 hits, 0 misses
RxQ15 buffers, 2040 bytes (total 4, permanent 4):
0 in free list (0 min, 4 max allowed)
6289058 hits, 6289054 misses
IPC buffers, 2048 bytes (total 300, permanent 300):
299 in free list (150 min, 500 max allowed)
1 hits, 0 fallbacks, 0 trims, 0 created
Are these misses an indication of my problem?
best regards /ti
10-26-2010 09:31 AM
Buffer misses do not indicate packet drop expecially on switched.
It is extremely unlikely that the switch is droppping packets,
However, try updating software and reload the switch.
10-26-2010 09:47 AM
You may get more traction on this one in the switching forum. Since you know you have drops, it's not a voice specific issue and the issue is related to the switch queues/QoS, and the issue needs to be looked at from a 3750 packet dropping perspective.
I don't have rights to move threads, though.
Message was edited by: Steven Holl
10-28-2010 05:02 AM
hi again
Well - I am not sure on how to interpret the output of "show buffers" - since the Cat is dropping RTP packets in transistion (no packets missing before the switch and missing RTP packets after) I would expect to find somewhere where it is low on buffers - and the only buffers I can find which shos "something" are these RxQ8 & RxQ15 buffers which seems to be pretty exhausted.
Could these buffers be my problem?
best regards /ti
10-28-2010 05:25 AM
As mentioned above - buffers do not matter on switches.
If you have qos and queue "tuning" commands, remove them all.
10-28-2010 08:47 AM
Like most switches the ASIC's are oversubscribed on the 3750. I usually find most drops on the ASIC. Try this command:
Switch# show controllers ethernet-controller port-asic statistics
Switch 1, PortASIC 0 Statistics
0 RxQ-0, wt-0 enqueue frames 0 RxQ-0, wt-0 drop frames
4118966 RxQ-0, wt-1 enqueue frames 0 RxQ-0, wt-1 drop frames
0 RxQ-0, wt-2 enqueue frames 0 RxQ-0, wt-2 drop frames
0 RxQ-1, wt-0 enqueue frames 0 RxQ-1, wt-0 drop frames
296 RxQ-1, wt-1 enqueue frames 0 RxQ-1, wt-1 drop frames
2836036 RxQ-1, wt-2 enqueue frames 0 RxQ-1, wt-2 drop frames
0 RxQ-2, wt-0 enqueue frames 0 RxQ-2, wt-0 drop frames
0 RxQ-2, wt-1 enqueue frames 0 RxQ-2, wt-1 drop frames
158377 RxQ-2, wt-2 enqueue frames 0 RxQ-2, wt-2 drop frames
0 RxQ-3, wt-0 enqueue frames 0 RxQ-3, wt-0 drop frames
0 RxQ-3, wt-1 enqueue frames 0 RxQ-3, wt-1 drop frames
0 RxQ-3, wt-2 enqueue frames 0 RxQ-3, wt-2 drop frames
15 TxBufferFull Drop Count 0 Rx Fcs Error Frames
0 TxBufferFrameDesc BadCrc16 0 Rx Invalid Oversize Frames
0 TxBuffer Bandwidth Drop Cou 0 Rx Invalid Too Large Frames
0 TxQueue Bandwidth Drop Coun 0 Rx Invalid Too Large Frames
0 TxQueue Missed Drop Statist 0 Rx Invalid Too Small Frames
74 RxBuffer Drop DestIndex Cou 0 Rx Too Old Frames
0 SneakQueue Drop Count 0 Tx Too Old Frames
0 Learning Queue Overflow Fra 0 System Fcs Error Frames
0 Learning Cam Skip Count
15 Sup Queue 0 Drop Frames 0 Sup Queue 8 Drop Frames
0 Sup Queue 1 Drop Frames 0 Sup Queue 9 Drop Frames
0 Sup Queue 2 Drop Frames 0 Sup Queue 10 Drop Frames
0 Sup Queue 3 Drop Frames 0 Sup Queue 11 Drop Frames
0 Sup Queue 4 Drop Frames 0 Sup Queue 12 Drop Frames
0 Sup Queue 5 Drop Frames 0 Sup Queue 13 Drop Frames
0 Sup Queue 6 Drop Frames 0 Sup Queue 14 Drop Frames
0 Sup Queue 7 Drop Frames 0 Sup Queue 15 Drop Frames
11-03-2010 05:49 AM
hi again
OK - this looks interesting - even though I cannot find drops on the ports where I expected to find drops - here is a snapshot of the switch - with a few minutes interval:
distrib-sw-001#sh platform port-asic stats drop gigabitEthernet 1/0/24
Interface Gi1/0/24 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 94587432
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 94588871
distrib-sw-001#
These weight 2 frames which seems to me to be dropped - what is this? It is pretty hard to find some documentations on what I in fact see here...
best regards /ti
