Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco 3750 POE
I need to know switch Cisco 3750 POE 10/100 48 Port can run Hikvission Cameras  on it or no.
13 Replies 13
balaji.bandi
what is the Full Model of Cisco 3750 ( check the model that support PoE)
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-series-switches/product_data_sheet0900aecd80371991.html
Hikvission Cameras  - Camera need 802.af - that should be ok for the switch to delivery power. (this is based on the document)
BB
yes, it is support POE but I'm afraid that the switch is only 10/100 not 10/100/1000
as long it has PoE that Camera meet the requirement of the power, the device should on. (have you tried it ?)
BB
Camera Power:12V  (POE 802.3af,37-57V)
as i mentioned that is standard of PoE, have you connected and tested ? what is the issue here ?
BB
Leo Laohoo
  1. What is the exact model of the switch?
  2. What is the exact amount of power draw of the camera?
Model: WS-C3750-48PS-S 10/100
That model can support up to 15.4wac but has a 375wac power budget.
you mean the switch is support the POE Cameras but will not have more than 25 cameras on it ,approximately.
If all cameras pull 15.4wac, then the switch can only power 24 cameras.
Thank you for the your help, and I'm sorry for any inconvenience.
