ā01-06-2014 05:10 PM - edited ā03-07-2019 05:24 PM
I am having performance issues with 2x48P 3750 Stacked switches. Overall performance is really bad in all spects: VoiP, Server Transfers, SAN and VM traffic. This is an inherited site and I am looking to improve network performance since it is terrible. By looking at some other forums my first impression is that stack is being overloaded with SAN and VM traffic. I am not sure if the Cisco stack is suited handle tons of traffic specially from the SAN and VM and I would like to have some advise. See my attached outputs expert advise would be great.
Switch Ports Model SW Version SW Image
1 54 WS-C3750X-48P 12.2(53)SE2 C3750E-UNIVERSALK9-M
* 2 54 WS-C3750X-48P 12.2(53)SE2 C3750E-UNIVERSALK9-M
Also i just noticed only on stack cable was installed and it shows as Half Speed. Would this also affect performance?
Stack Ring Speed : 16G
Stack Ring Configuration: Half
Stack Ring Protocol : StackWisePlus
Thanks in Advance.
Solved! Go to Solution.
ā01-06-2014 05:45 PM
Here are my recommendations:
1. Upgrade your IOS. It's buggy.
2. Install the second stacking cable.
3. Observe for any improvements.
4. Remove SAN.
5. Observe for any improvements.
ā01-06-2014 05:15 PM
Correct. Cisco Catalyst switches are not designed to handle SAN traffic. Period. You want switch for SAN traffic? It's Cisco Nexus.
Next, your IOS. It's one of THE worst IOS. Try 12.2(55)SE8.
ā01-06-2014 05:23 PM
Thanks I will start with taking off the SAN traffic out this stack. How about the the the situation with one stack cable. Would connecting the second cable help performarce and can this be plugged as a hot swap.
ā01-06-2014 05:37 PM
See this:
This is the maximum theoretical ring speed (bandwidth) for a Catalyst 3750 switch, by adding a second cable and complete the ring you should have 32 Gb/s of bandwidth.
ā¢32 Gb/s with a full or complete StackWise ring
ā¢16 Gb/s with an incomplete or open ring, only one StackWise cable on two switches in the ring
ā01-06-2014 05:43 PM
Not a smart idea. Use two cables.
One cable means you're only operating at half the stackring speed.
ā01-06-2014 05:44 PM
It would slightly improve performance and it can be installed while the switches are powered on.
4. Remove SAN.
ā01-06-2014 05:52 PM
Thank you all for your advise.
ā01-07-2014 07:07 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As noted in other posts, getting 2nd stack cable in operation will double bandwidth between stack members. However, 3750 series are noted for insufficient port buffers to handle (well) transient bursts, so I would first suspect issues there rather than on the stack (but it's still worthwhile to get the 2nd stack port in operation.)
Look for packet drops on ports. If there's much, check whether QoS is enabled. If so, determine whether you need QoS. If not, disable QoS. If needed, you may need to tune buffer usage parameters.
Also on the 3750X series, the "uplink" ports have more memory for the number of ports than the copper ports do. So if you have high drop rate ports (SAN devices?), if not already using them, move those ports to available "uplink" ports (if copper, you'll need copper SFPs).
Other alternative for very high usage gig ports, if possible, consider Etherchannel and/or 10g.
Leo's suggestion to upgrade IOS, besides addressing bugs, may (cough - NDA - cough) offer some other improvements.
ā01-07-2014 02:13 PM
You really need to get that cough fixed, Joseph. You've been having a lot of coughing fits lately.
