05-12-2021 07:10 AM - edited 05-20-2021 12:32 PM
Hello Cisco experts,
I have a Cisco switch (3750) that is having an issue when selecting options under port configuration. I am able to access all other sections/options fine, but when I select to set a port and putting in a description and attempt to save I get a 404 error every time.
This only occurs with port setting, and this is an airgap system...any ideas?
Thank you in advance.
05-12-2021 07:58 AM
Can you post the screenshot of the issue
from command levle can you post below output :
show version
dir
05-20-2021 12:20 PM
Hello, and thank you for replying.
The issue is occurring on cisco switches 3850, with version number 16.06.02.
I am not able to take picture because they are air gapped and in a different department.
Thank you,
05-20-2021 12:26 PM
05-20-2021 07:46 PM
not sure is this switch using ISE for AAA ? as per the screenshot to show as ISE ?
05-21-2021 06:00 AM
05-21-2021 06:09 AM
ISE node is setup in distributed deployment. Thought it was standalone, but there are more than one switches...sorry I am new to the environment.
