Cisco 3750 switches security
Hi All,
Can someone please help with the following question?
1. Does the Cisco switches support more secured certificate method other than MD5 algorithms?
2. How do we confirm if the switch Version 2 cannot be accessed via Version 1.
Please help.
VLA_WeyBridge_2
I belive it supposts SHA as well as MD5
and version 1 and 2 of what?
if its ssh authentication you are talking about you can use a program such as teraterm to chose what version you want to connect with. set it to version 1 and see what happens.
