11-27-2013 06:32 AM - edited 03-07-2019 04:48 PM
I have 2 3750s connected via flexstack. Its working good no issues.
I have 8 2960s (each in stack of 4).
Each stack of 2960s, is connected via a port-channel to my 3750. But, I have a backup port-channel to my second 3750, just in case my first 3750 goes down.
I dont want to have both connections up, I just want it so that in case one of the connections goes down, the secondary one takes over.
Isnt that done thru spanning-tree cost?
This is my setup:
3750
The primary Connection:
interface Port-channel2
description Uplink to ETHSW05
snmp trap mac-notification change added
snmp trap mac-notification change removed
spanning-tree guard loop
spanning-tree cost 15
The backup port-channel
interface Port-channel4
description BRP to ETHSW05
Is my setup correct? Cause at the moment, both port-channels shows as up. Basically, I just want 2 2GB connections to each stack, one of them being a backup in case the first fails.
Thanks for the help...
11-27-2013 06:41 AM
In a case when you have 2 portchannels to the same switch, the second portchannel will be in blocking mode, but the interfaces are still in up and up mode. So, STP blocks one of them.
11-27-2013 06:43 AM
Thank you.
So my configuration is correct?
Thanks...
11-27-2013 06:54 AM
Pick a vlan that is allowed on both both port channel interfaces and then do -
sh spanning-tree vlan
and you should see it being blocked on one of the switches. You should do this on he 2960s.
Jon
11-27-2013 06:55 AM
Hi Reza
Forgot to reply when i saw you in another post. Hope all is well with you
Jon
11-27-2013 06:58 AM
Hi Jon,
All is well, thanks.
Good to see you are back after a long pause.
Have you recovered completely from your bike injury?
Reza
11-27-2013 05:03 PM
Reza
Pretty much yes although i do still get the odd twinge every now and then.
Glad to see your'e still active and i am learning more about VSS every time i read one of your posts.
Jon
