04-19-2019 07:14 AM
just a simple little question, but i wasn't able to find my answers i the documentary.
I know i can "shop ip dhcp pool" and so on to show dhcp pools. And i know how to change the dns and gateway for one pool. But how can i show and read the current configuratoin for a dhcp pool ? How can i see what dns and gateway my predecessor configured for a pool?
Solved! Go to Solution.
04-21-2019 01:51 AM
You can see the mentioned details in the running configuration as
show running-config
or you can use the special command as
show running-config | section ip dhcp
You will found the commands as like:
ip dhcp pool <Pool-Name>
network 192.168.0.0 /24
domain-name ciscolab.com
dns-server 192.168.1.1 8.8.8.8
04-19-2019 07:17 AM
If you issue "show run", the switch will show you all the config including DNS and gateway.
04-20-2019 03:08 PM
you may see example in the running as below :
ip dhcp pool 0
network 172.16.0.0 /16
domain-name cisco.com
dns-server 172.16.1.102 172.16.2.102
04-21-2019 01:51 AM
show running-config
