Cisco 3825 Problem
dssamxara
Upon booting a 3825 i get - Changed RAM but still the same
program load complete, entry point: 0x8000f000, size: 0xcb40
program load complete, entry point: 0x80010000, size: 0x2510ad4
Self decompressing the image : ################################################################################################################################################################################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
00042A 0X010D78F3 C3825 motherboard
000056 0X000C2800 4-port FE Switch HWIC
0X00288860 DSP SIMM
0X0027250A Onboard VPN
0X000021B8 Onboard USB
0X00660670 public buffer pools
0X0078F000 public particle pools
TOTAL: 0X02486685
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 37Mb.
Using 3 percent iomem. [37Mb/1024Mb]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, 3800 Software (C3825-ADVIPSERVICESK9-M), Version 12.4(18a), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Mon 24-Mar-08 20:32 by prod_rel_team
Image text-base: 0x60010E5C, data-base: 0x62B7FF40
Host PCI-Bridge Error: RMBORT
Address causing error: 0x00100000
Possible software fault. Upon reccurence, please collect
crashinfo, "show tech" and contact Cisco Technical Support.
Trace buffer contents:
21 Blockers: scd
D-bus: mc -> cpu0 :07 dcode: DVal dirty? no
Data _00000000_00000000_00000000_00000000_00000000_00000000_00000000_00000000_
29 Blockers: scd
D-bus: mc -> cpu0 :06 dcode: DVal dirty? no
38 Blockers: (none)
A-bus:READ_EXC cpu0 :07 0x0004BEE6C0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
44 Blockers: (none)
A-bus:READ_EXC cpu0 :00 0x0004BEE6E0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
49 Blockers: scd
A-bus:WRITE l2 :00 0x000589E6E0 be: FFFFFFFF CC/U l2miss shd:0 exc:0
52 Blockers: (none)
D-bus: WriteData l2 :00 dcode: DVal dirty? no
Data _7000D3C0_00000000_7000D3C0_00000020_0000003A_00140014_00000023_00000000_
73 Blockers: scd
78 Blockers: (none)
A-bus:WRITE cpu0 :22 0x00058CC6C0 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
81 Blockers: scd
D-bus: WriteData cpu0 :22 dcode: DVal dirty? yes
Data _0D0D0D0D_0D0D0D0D_0D0D0D0D_0D0D0D0D_0D0D0D0D_0D0D0D0D_0D0D0D0D_0D0D0D0D_
82 Blockers: (none)
D-bus: mc -> cpu0 :00 dcode: DVal dirty? no
87 Blockers: scd
A-bus:WRITE cpu0 :23 0x00058CC6E0 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
90 Blockers: (none)
D-bus: WriteData cpu0 :23 dcode: DVal dirty? yes
Data _DC5678BB_FFFE0000_00000000_63C0E5C4_625E7510_658CC750_658CC5EC_00000020_
91 Blockers: scd
A-bus:READ_EXC cpu0 :07 0x0004BEE700 be: FFFFFFFF CC/C l2miss shd:0 exc:0
96 Blockers: (none)
A-bus:WRITE l2 :00 0x008008E700 be: FFFFFFFF CC/U l2miss shd:0 exc:0
98 Blockers: (none)
A-bus:READ_EXC cpu0 :00 0x0004BEE720 be: FFFFFFFF CC/C l2miss shd:0 exc:0
99 Blockers: scd
Data _FFFFFFFF_FFFFFFFF_FFFFFFFF_FFFFFFFF_FFFFFFFF_FFFFFFFF_FFFFFFFF_FFFFFFFF_
125 Blockers: scd
130 Blockers: (none)
A-bus:WRITE cpu0 :24 0x00058CC700 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
133 Blockers: scd
D-bus: WriteData cpu0 :24 dcode: DVal dirty? yes
Data _00000000_625E759C_00000001_70012BEC_BEEFBACC_625E759C_00000000_0D0D0D0D_
134 Blockers: (none)
139 Blockers: scd
A-bus:WRITE cpu0 :25 0x00058CC720 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
142 Blockers: (none)
D-bus: WriteData cpu0 :25 dcode: DVal dirty? yes
Data _658CC564_64BA3DE8_0D0D0D0D_0D0D0D0D_0D0D0D0D_0D0D0D0D_0D0D0D0D_0D0D0D0D_
143 Blockers: scd
A-bus:READ_EXC cpu0 :07 0x0004BEE740 be: FFFFFFFF CC/C l2miss shd:0 exc:0
149 Blockers: scd
A-bus:READ_EXC cpu0 :06 0x0004BEE760 be: FFFFFFFF CC/C l2miss shd:0 exc:0
177 Blockers: scd
185 Blockers: scd
194 Blockers: (none)
A-bus:READ_EXC cpu0 :07 0x0004BEE780 be: FFFFFFFF CC/C l2miss shd:0 exc:0
200 Blockers: (none)
A-bus:READ_EXC cpu0 :06 0x0004BEE7A0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
229 Blockers: scd
237 Blockers: scd
246 Blockers: (none)
A-bus:READ_EXC cpu0 :07 0x0004BEE7C0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
252 Blockers: (none)
A-bus:READ_EXC cpu0 :00 0x0004BEE7E0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
305 Blockers: scd
309 Blockers: scd
316 Blockers: (none)
A-bus:WRITE cpu0 :26 0x00C01E87E0 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
319 Blockers: scd
D-bus: WriteData cpu0 :26 dcode: DVal dirty? yes
Data _625E759C_00000001_70012BEC_BEEFBACC_625E759C_625E759C_0D0D0D0D_64BA429C_
322 Blockers: (none)
A-bus:READ_EXC cpu0 :00 0x0004BEE800 be: FFFFFFFF CC/C l2miss shd:0 exc:0
327 Blockers: scd
A-bus:WRITE l2 :00 0x008008E800 be: FFFFFFFF CC/U l2miss shd:0 exc:0
328 Blockers: (none)
A-bus:READ_EXC cpu0 :07 0x0004BEE820 be: FFFFFFFF CC/C l2miss shd:0 exc:0
330 Blockers: (none)
333 Blockers: scd
A-bus:WRITE l2 :00 0x00C01DE820 be: FFFFFFFF CC/U l2miss shd:0 exc:0
336 Blockers: (none)
357 Blockers: scd
362 Blockers: (none)
A-bus:WRITE cpu0 :27 0x00058CC800 be: FFFFFFFF CC/C l2miss shd:0 exc:0
365 Blockers: scd
D-bus: WriteData cpu0 :27 dcode: DVal dirty? yes
Data _701E88B4_64BA4298_0D0D0D0D_0D0D0D0D_DC5678BB_00000000_00000000_62B81494_
366 Blockers: (none)
375 Blockers: scd
A-bus:READ_EXC cpu0 :07 0x0004BEE840 be: FFFFFFFF CC/C l2miss shd:0 exc:0
382 Blockers: (none)
A-bus:READ_EXC cpu0 :00 0x0004BEE860 be: FFFFFFFF CC/C l2miss shd:0 exc:0
409 Blockers: scd
417 Blockers: scd
426 Blockers: (none)
A-bus:READ_EXC cpu0 :07 0x0004BEE880 be: FFFFFFFF CC/C l2miss shd:0 exc:0
433 Blockers: scd
A-bus:READ_EXC cpu0 :00 0x0004BEE8A0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
461 Blockers: scd
469 Blockers: scd
478 Blockers: (none)
A-bus:READ_EXC cpu0 :07 0x0004BEE8C0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
484 Blockers: (none)
A-bus:READ_EXC cpu0 :06 0x0004BEE8E0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
494 Blockers: (none)
A-bus:READ_SHD cpu0 :30 0x000066E820 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
498 Blockers: (none)
D-bus: l2 -> cpu0 :30 dcode: DVal dirty? no
Data _00003021_00002021_240500A5_0C0A54EB_00003821_00403021_3043FFFF_240211AB_
506 Blockers: (none)
A-bus:READ_SHD cpu0 :30 0x00002953A0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
513 Blockers: scd
521 Blockers: scd
541 Blockers: scd
D-bus: mc -> cpu0 :30 dcode: DVal dirty? no
Data _0002102B_03E00008_27BD0018_3C0864BA_8D0350CC_27BDFFE0_AFBF0018_AFA00010_
548 Blockers: (none)
A-bus:READ_SHD cpu0 :30 0x00002953C0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
583 Blockers: scd
Data _8C62002C_308400FF_30A500FF_30C600FF_0040F809_30E700FF_8FBF0018_03E00008_
591 Blockers: scd
A-bus:READ_SHD cpu0 :00 0x000448A260 be: FFFFFFFF CC/C l2miss shd:0 exc:0
595 Blockers: scd
A-bus:READ_SHD cpu0 :30 0x0000A179A0 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
599 Blockers: scd
Data _00001812_082BAD0C_00A02021_27BDFFE8_2C820105_AFB00010_AFBF0014_14400026_
606 Blockers: (none)
A-bus:READ_SHD cpu0 :30 0x0000A179C0 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
610 Blockers: (none)
Data _00808021_0C2BC687_00000000_14400011_3C0564C9_8CA4E340_2403002B_1083000D_
625 Blockers: scd
Data _6029AD14_602995A8_60299668_6029B0DC_602952AC_602952B4_602952BC_6029530C_
630 Blockers: (none)
A-bus:WRITE cpu0 :20 0x00056AA260 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
633 Blockers: scd
A-bus:READ_SHD cpu0 :30 0x0000299660 be: FFFFFFFF CC/C l2miss shd:0 exc:0
D-bus: WriteData cpu0 :20 dcode: DVal dirty? yes
Data _656AA408_00000000_00000000_00000000_600258A4_00000000_00000000_00000000_
667 Blockers: scd
Data _03E00008_27BD0028_27BDFFD8_AFB20020_AFB1001C_AFBF0024_AFB00018_3C026449_
674 Blockers: (none)
A-bus:READ_SHD cpu0 :30 0x0000299680 be: FFFFFFFF CC/C l2miss shd:0 exc:0
709 Blockers: scd
Data _8C42AE88_30D100FF_A3A5002C_A3A40028_27A5002C_27A40028_27A60010_10400003_
716 Blockers: (none)
A-bus:READ_SHD cpu0 :30 0x00002996A0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
717 Blockers: scd
A-bus:READ_SHD cpu0 :00 0x000448AE80 be: FFFFFFFF CC/C l2miss shd:0 exc:0
751 Blockers: scd
Data _30F200FF_0040F809_00000000_93AD002C_93AC0028_32280007_31A4001F_000452C0_
755 Blockers: scd
Data _6029AC40_6029B03C_60295314_00000000_00000001_00000000_00000000_00000000_
759 Blockers: scd
A-bus:READ_SHD cpu0 :30 0x00002996C0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
769 Blockers: scd
A-bus:READ_SHD cpu0 :31 0x0000295300 be: FFFFFFFF CC/C l2miss shd:0 exc:0
799 Blockers: scd
Data _000C4C00_3C0B6375_8D64AC14_012A3025_00083A00_00C72825_324300FC_0C2B9F80_
803 Blockers: scd
D-bus: mc -> cpu0 :31 dcode: DVal dirty? no
Data _24630020_03E00008_00801021_03E00008_00A01021_90820000_14400019_00000000_
813 Blockers: scd
A-bus:READ_SHD cpu0 :30 0x0000295320 be: FFFFFFFF CC/C l2miss shd:0 exc:0
847 Blockers: scd
Data _90A60000_24CAFFF9_24C9FFF7_314800FF_312300FF_2D070002_10E00003_2C630002_
854 Blockers: (none)
A-bus:READ_SHD cpu0 :30 0x0000295340 be: FFFFFFFF CC/C l2miss shd:0 exc:0
859 Blockers: scd
A-bus:READ_SHD cpu0 :31 0x0000295340 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
889 Blockers: scd
Data _080A54D5_2402000C_10600004_30C600FF_24020003_03E00008_A0820000_240400A5_
899 Blockers: scd
D-bus: l2 -> cpu0 :31 dcode: DVal dirty? no
907 Blockers: scd
A-bus:READ_SHD cpu0 :30 0x0000295360 be: FFFFFFFF CC/C l2miss shd:0 exc:0
941 Blockers: scd
Data _14C40004_240B00A0_24060009_03E00008_A0A60000_14CB0002_240C000A_A0AC0000_
954 Blockers: (none)
A-bus:READ_SHD cpu0 :30 0x00002996C0 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
958 Blockers: (none)
965 Blockers: scd
A-bus:READ_SHD cpu0 :30 0x00002996E0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
970 Blockers: (none)
A-bus:WRITE l2 :00 0x00058C96E0 be: FFFFFFFF CC/U l2miss shd:0 exc:0
973 Blockers: scd
999 Blockers: scd
Data _00A39025_02402021_0C2BA9A0_00408821_00408021_0C2BA51A_02202021_02001021_
1008 Blockers: (none)
A-bus:READ_SHD cpu0 :30 0x0000AE7E20 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
1012 Blockers: (none)
Data _00000000_27888138_8D090000_25290001_03E00008_AD090000_40A4F000_40086000_
1025 Blockers: scd
A-bus:READ_SHD cpu0 :30 0x0000AEA680 be: FFFFFFFF CC/C l2miss shd:0 exc:0
1059 Blockers: scd
Data _40086000_2409FFFE_01284824_40896000_00000000_00000000_00000000_00000000_
1066 Blockers: (none)
A-bus:READ_SHD cpu0 :30 0x0000AEA6A0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
1071 Blockers: scd
A-bus:WRITE l2 :00 0x000568A6A0 be: FFFFFFFF CC/U l2miss shd:0 exc:0
1074 Blockers: (none)
Data _6568A690_64B08738_00000026_00090000_00000050_00000000_64082100_621FD804_
1101 Blockers: scd
Data _00000000_00000000_00000000_00000000_240A0080_012A4825_40896000_00000000_
1108 Blockers: (none)
A-bus:READ_SHD cpu0 :30 0x0000AEA6C0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
1143 Blockers: scd
Data _00000000_00000000_00000000_00000000_00000000_00000000_00000000_3C0B00FF_
1150 Blockers: (none)
A-bus:READ_SHD cpu0 :30 0x0000AEA6E0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
1155 Blockers: scd
A-bus:WRITE l2 :00 0x00056AA6E0 be: FFFFFFFF CC/U l2miss shd:0 exc:0
1158 Blockers: (none)
Data _FFFFFFFF_00000000_00000000_656AA838_656AA8B8_61669AE4_6166A5D4_656AA7AC_
1185 Blockers: scd
Data _356BFFFF_008B2024_3C0B9000_000B5C38_356BFE00_000B5C38_008B2025_8C820000_
1192 Blockers: (none)
A-bus:READ_SHD cpu0 :30 0x0000AEA700 be: FFFFFFFF CC/C l2miss shd:0 exc:0
1197 Blockers: scd
A-bus:WRITE l2 :00 0x00056AA700 be: FFFFFFFF CC/U l2miss shd:0 exc:0
1200 Blockers: (none)
Data _656AA728_00000001_00000000_00000000_63CD5270_61671B64_00000000_656AA730_
1202 Blockers: (none)
A-bus:READ_SHD cpu0 :00 0x00FE004800 be: F0000000 U0/U l2miss shd:0 exc:0
1227 Blockers: scd
Data _00000000_40886000_00000000_00000000_00000000_00000000_00000000_00000000_
1234 Blockers: (none)
A-bus:READ_SHD cpu0 :30 0x0000AEA720 be: FFFFFFFF CC/C l2miss shd:0 exc:0
BCM1250 HT Host Bridge, handle=0
BCM bridge, config=0x0
(0x00):dev, vendor id = 0x0002166D
(0x04):status, command = 0x00100107
(0x08):class code, revid = 0x06000003
(0x0C):hdr, lat timer, cls = 0x00010000
(0x18):bus id registers = 0x00130100
(0x1C):secondary status = 0x00000141
(0x20):mem base/limit = 0x59F05000
(0x30):io upper limit/base = 0x00010001
(0x34):capabilities ptr = 0x00000040
(0x38):expansion rom bar = 0x00000000
(0x3C):bridge ctrl = 0x00020000
(0x40):LDT cmd, cap id, = 0x20000008
(0x44):Link config/control = 0x00000020
(0x48):Link frequency = 0x801F0423
(0x50):SRIcmd, srirxden, sritxden = 0x50211010
(0x54):SRI tx numerator = 0x0000FFFF
(0x58):SRI rx numerator = 0x0000FFFF
(0x68):Error status/control = 0x00009A49
(0x6C):Tx ctrl, databufalloc = 0x00041515
(0xC8):Tx buffer count max = 0x00FFFFFF
(0xDC):Rx CRC expected = 0xCF49E4BA
(0xF0):Rx CRC received = 0x37FBF77F
System bridge dump:
PLX HT2PCI 1 Bridge A for FIO 0, handle=0
PLX HT7520 bridge, config=0x0
(0x00):dev, vendor id = 0x74501022
(0x04):status, command = 0x02300107
(0x08):class code, revid = 0x06040012
(0x0C):hdr, lat timer, cls = 0x00810000
(0x18):bus id registers = 0x080A0201
(0x1C):secondary status = 0x02200141
(0x20):mem base/limit = 0x51F05000
(0x34):capabilities ptr = 0x000000A0
(0x3C):bridge ctrl = 0x00210000
(0x40):miscellaneous = 0x001F0007
(0x4C):prefetch ctrl = 0x00000446
(0xC0):ht cmd, cap id = 0x00410008
(0xC4):link cfg/ctrl side a = 0x00112022
(0xC8):link cfg/ctrl side b = 0x770020D2
(0xCC):link freq ctrl side a = 0x00350422
(0xD0):link freq ctrl side b = 0x00350402
PLX HT2PCI 1 Bridge B, for FIO 1
(0x18):bus id registers = 0x08130B01
(0x1C):secondary status = 0x022001A1
(0x20):mem base/limit = 0x59F05800
PA bridge dump:
AIM slots bridge dump:
r0 = FFFFFFFF r1 = FFFFFFFF r2 = 0 r3 = 64950000 r4 = FFFFFFFF
r5 = FFFFFFFF r6 = 0 r7 = 0 r8 = 90000000 r9 = FE004800
r10 = 0 r11 = 4800 r12 = 0 r13 = 4800 r14 = 0
r15 = 0 r16 = 0 r17 = 3400C101 r18 = 0 r19 = 3400C180
r20 = 0 r21 = 80 r22 = 90000000 r23 = FE000000 r24 = 0
r25 = 0 r26 = 0 r27 = 9 r28 = 0 r29 = 1
r30 = 0 r31 = 1 r32 = FFFFFFFF r33 = FFFFFFFF r34 = FFFFFFFF
r35 = FFFFFFFF r36 = FFFFFFFF r37 = FFFFFFFF r38 = FFFFFFFF r39 = FFFFFFFF
r40 = FFFFFFFF r41 = FFFFFFFF r42 = FFFFFFFF r43 = FFFFFFFF r44 = FFFFFFFF
r45 = FFFFFFFF r46 = FFFFFFFF r47 = FFFFFFFF r48 = 0 r49 = 606632AC
r50 = 0 r51 = 632A6380 r52 = 0 r53 = 30408001 r54 = FFFFFFFF
r55 = B0020000 r56 = FFFFFFFF r57 = FFFFFFFF r58 = 0 r59 = 656AAA08
r60 = FFFFFFFF r61 = FFFFFFFF r62 = 0 r63 = 602996F0
sreg = 3400C103 mdlo_hi = 0 mdlo = F4240
mdhi_hi = 0 mdhi = 0 badvaddr_hi = FFFFFFFF
badvaddr = FFFFFFFF cause = FFFFFFFF epc_hi = 0
epc = 60AEA720 err_epc_hi = FFFFFFFF err_epc = FFFFFFFF
%ERR-1-FATAL: Fatal error interrupt, reloading
err_stat=0x0
=== Flushing messages (15:03:59 UTC Wed Jan 13 2016) ===
Queued messages:
15:04:00 UTC Wed Jan 13 2016: Interrupt exception, CPU signal 22, PC = 0x0
-Traceback=
$0 : 00000000, AT : 00000000, v0 : 00000000, v1 : 00000000
a0 : 00000000, a1 : 00000000, a2 : 00000000, a3 : 00000000
t0 : 00000000, t1 : 00000000, t2 : 00000000, t3 : 00000000
t4 : 00000000, t5 : 00000000, t6 : 00000000, t7 : 00000000
s0 : 00000000, s1 : 00000000, s2 : 00000000, s3 : 00000000
s4 : 00000000, s5 : 00000000, s6 : 00000000, s7 : 00000000
t8 : 00000000, t9 : 00000000, k0 : 00000000, k1 : 00000000
gp : 00000000, sp : 00000000, s8 : 00000000, ra : 00000000
EPC : 00000000, ErrorEPC : 00000000, SREG : 00000000
MDLO : 00000000, MDHI : 00000000, BadVaddr : 00000000
DATA_START : 0x62B7FF40
Cause 00000000 (Code 0x0): Interrupt exception
Writing crashinfo to flash:crashinfo_20160113-150401
Philip D'Ath
If you have already swapped out the RAM, then you probably have a more severe hardware issue.  You could try removing any modules and add on cards.
I hope you have a service contract like SmartNet.  You need to contact Cisco TAC and arrange a hardware swap out.
