07-24-2005 08:30 PM - edited 03-05-2019 11:35 AM
Dear Sir,
We have Cisco 3845 Router.I inserted the WIC-1B-S/T - 1 port isdn bri card to the HWIC Slot.but it it not recognized.
Kindly help me to find out the solution.
Thanks in advance.
regards
nagarajan
hyundai motor india
07-24-2005 09:57 PM
Hello Nagarajan,
looking at the data sheet (see link below) it appears that the WIC-1B-S/T is not supported on the 3845, you need the WIC-1B-S/T-V3, as well as IOS 12.3(11)T...
Cisco 3800 Series Integrated Services Routers
Data Sheet
http://www.cisco.com/en/US/products/ps5855/products_data_sheet09186a0080091b87.html
HTH,
GP
07-25-2005 03:57 AM
Cisco ISR router does nto support WIC-1B-S/T. They supports a newer version od BRI cards which is WIC-1B-S/T-v3.
On router run show diag command. There in the wic slot if you see on WIC-1B-S/T then you need to change the card and have to get this newer version. Otherwise it may be some other issue.
If you find any difficulty in reading that output just send it across and I will help you finding the issue.
Sushil
