09-27-2018 12:17 AM - edited 03-08-2019 04:15 PM
Failing Address: 0x0000000002026908, Data: 0x7830303030303030
ERROR LMC0 ECC: sec_err:1 ded_err:0
LMC0 ECC: Failing dimm: 0
LMC0 ECC: Failing rank: 0
LMC0 ECC: Failing bank: 1
LMC0 ECC: Failing row: 0x202
LMC0 ECC: Failing column: 0x9a0
LMC0 ECC: syndrome: 0xd6
Failing Address: 0x0000000002026880,
09-27-2018 12:35 AM
Suggest to raise an TAC case.
09-27-2018 12:36 AM
09-27-2018 02:05 AM
I did it but this the what is the switch showing
https://software.cisco.com/download/home/286257123/type/282046477/release/Denali-16.3.6
cat3k_caa-universalk9.16.03.06.SPA.bin
emergency-install tftp://192.0.2.1/cat3k_caa-universalk9.16.03.06.SPA.bin
Booting...
Getting rest of image
Reading full image into memory...Check base package header ...: done = 16384
Reading full image into memory....done
Reading full base package into memory...: done = 81992100
Bundle Image
Kernel Address : 0x5342e34c
Kernel Size : 0x3fb4ba/4175034
Initramfs Address : 0x53829808
Initramfs Size : 0xd47999/13924761
Compression Format: .mzip
Bootable image at @ ram:0x5342e34c
Bootable image segment 0 address range [0x81100000, 0x820b0000] is in range [0x80180000, 0x90000000].
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@boot_system: 377
Failing Address: 0x00000000f3639e68, Data: 0x0000000000000000
ERROR LMC0 ECC: sec_err:8 ded_err:0
LMC0 ECC: Failing bank: 4
LMC0 ECC: Failing row: 0x113
LMC0 ECC: Failing column: 0xc9e
Failing Address: 0x0000000001132678, Data: 0x35ceff0001a26814
ERROR LMC0 ECC: sec_err:2 ded_err:0
LMC0 ECC: Failing bank: 5
LMC0 ECC: Failing row: 0x124
LMC0 ECC: Failing column: 0x1100
Failing Address: 0x0000000001244288, Data: 0x0000502d0000582d
LMC0 ECC: Failing bank: 0
LMC0 ECC: Failing row: 0x167
LMC0 ECC: Failing column: 0x1f28
Failing Address: 0x000000000167c840, Data: 0x0000282ddfbf0008
Failing Address: 0x000000000167ca48, Data: 0x0040f8090200202d
ERROR LMC0 ECC: sec_err:3 ded_err:0
LMC0 ECC: Failing column: 0x9c0
Failing Address: 0x0000000002027200, Data: 0x0000000000000000
ERROR LMC0 ECC: sec_err:12 ded_err:0
LMC0 ECC: Failing bank: 7
LMC0 ECC: Failing row: 0xf7c8
LMC0 ECC: Failing column: 0x2002
Failing Address: 0x00000000f7c80390, Data: 0x0000000000000000
LMC0 ECC: Failing bank: 3
LMC0 ECC: Failing row: 0xe81c
LMC0 ECC: Failing column: 0x30bc
Failing Address: 0x00000000e81c2de8, Data: 0x0000000000000000
LMC0 ECC: Failing row: 0xd81c
Failing Address: 0x00000000d81c2ce8, Data: 0x0000000000000000
LMC0 ECC: Failing row: 0xc81c
Failing Address: 0x00000000c81c2de8, Data: 0x0000000000000000
LMC0 ECC: Failing row: 0xb81c
Failing Address: 0x00000000b81c2ce8, Data: 0x0000000000000000
LMC0 ECC: Failing row: 0xa81c
Failing Address: 0x00000000a81c2de8, Data: 0x0000000000000000
LMC0 ECC: Failing row: 0x981c
Failing Address: 0x00000000981c2ce8, Data: 0x0000000000000000
LMC0 ECC: Failing row: 0x881c
Failing Address: 0x00000000881c2de8, Data: 0x0000000000000000
LMC0 ECC: Failing row: 0x781c
Failing Address: 0x00000000781c2ce8, Data: 0x0000000000000000
LMC0 ECC: Failing row: 0x681c
Failing Address: 0x00000000681c2de8, Data: 0x0000000000000000
LMC0 ECC: Failing row: 0x581c
Failing Address: 0x00000000581c2ce8, Data: 0xa6b571701b7ece7b
LMC0 ECC: Failing row: 0x481c
Failing Address: 0x00000000481c2de8, Data: 0x0000000000000000
LMC0 ECC: Failing row: 0x381c
Failing Address: 0x00000000381c2ce8, Data: 0x0000000000000000
LMC0 ECC: Failing row: 0x281c
Failing Address: 0x00000000281c2de8, Data: 0xdc911b4dd92b5dbb
Data bus error, epc == ffffffff811326d8, ra == ffffffff81130b70
CRASHINFO_OOPS:
Oops[#1]:
Cpu 0
$ 0 : 0000000000000000 0000000010108ce1 a800000000000000 00000000181c2cf0
$ 4 : ffffffff81d5d3a0 0000000000000000 000000000000000c 0000000000000000
$ 8 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000
$12 : 00000000000000d6 00000000181c0000 0000000000ffff00 0000000000000010
$16 : ffffffff820073f8 0000000000000018 00000000000000f7 ffffffff82007338
$20 : ffffffff82000000 0000000000000060 ffffffff82001698 0000000000000000
$24 : 00000000000c2c00 0000000000000080
$28 : ffffffff81f08000 ffffffff81f0ba30 ffffffff811309f8 ffffffff81130b70
Hi : 0000000000000000
Lo : 0000000000005ca0
epc : ffffffff811326d8 __cvmx_cn6xxx_lmc_ecc_error_display+0x298/0x3c0
Not tainted
ra : ffffffff81130b70 __cvmx_error_decode+0x178/0x1e8
Status: 10108ce3 KX SX UX KERNEL EXL IE
Cause : 4080801c
PrId : 000d900a (Cavium Octeon II)
Modules linked in: rtc_ds1307
Process swapper (pid: 0, threadinfo=ffffffff81f08000, task=ffffffff81f29c80, tls=0000000000000000)
Stack : 0000000000000000 0000000000000001 0000000000000000 000000000000181c
0000000000000000 00000000000030be 0000000000000000 00000000000000d6
00000000181c2cf0 dc911b4dd92b5dbb ffffffff811309f8 ffffffff81130b70
0000000000000007 0000000000000000 ffffffff82001cf8 0000000000020000
00000000000000f9 ffffffff820073f8 ffffffff82000000 0000000000000060
ffffffff82001698 0000000000000002 ffffffff811309f8 ffffffff81130af0
0000000000000000 00000000d0052c80 ffffffff82001d58 0000000000000012
ffffffff82000000 0000000000000000 ffffffff81fa4000 0000000000000001
0000000000000002 ffffffffffffffff 000000000000008a ffffffff81130c40
0000000000000008 0000000000000000 0000000000000000 000000000000008a
Call Trace:
[<ffffffff811326d8>] __cvmx_cn6xxx_lmc_ecc_error_display+0x298/0x3c0
[<ffffffff81130b70>] __cvmx_error_decode+0x178/0x1e8
[<ffffffff81130af0>] __cvmx_error_decode+0xf8/0x1e8
[<ffffffff81130c40>] cvmx_error_poll+0x60/0xa0
[<ffffffff81100ed8>] octeon_rml_interrupt+0x10/0x20
[<ffffffff812c79a4>] handle_IRQ_event+0x94/0x3a0
[<ffffffff812ca6d8>] handle_level_irq+0xb0/0x170
[<ffffffff81235624>] do_IRQ+0x2c/0x40
[<ffffffff81102f34>] plat_irq_dispatch+0x74/0xb8
[<ffffffff81233ae0>] ret_from_irq+0x0/0x4
t 00ttt 0000 0000xxxx00x000000000000000000000000000000000000000000000000000000000000000000000000000 000t tttt1111 1 00 xx0000xxx00000000000000000000000000000000000001100001110000000000000000000011000f111ffff
tt 2ttt2222 00 0xx000axxx8aaa0888000000000000000000000000001110010080001888922201804e000480000000001000 tt t33tt 3330 0000xxxxa0x0800000000000000000000000000001000000000000800000001000500000000300020000000
ssss00s0 0000 x000xxxxfffffffffffffffffffffffffffffffffffff88fff288822200202200002220000000000000000 00ss 1sss1111 00 0xx00ffxxxffffffffffff000ffffffffffffffffffffff88f81188ff1110fff0000cccc99c9999900999
ss 22sss 222 0000xx0xffxxffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffeefff eee ssss33s3 3300 x000xxxx0000000000000000000000000000000000000000000000000022220020000022000022200000000
s ssss4444 4 00 xx000axxxaaaa88880080000000000000000000001100001113000333388888888998899999799977770000 0ss 55sss 555 0000xx0xffxxffffffffffffffffffffffffff000fffffffff88881181ff1100fffc000cccc999988980088
ss s66ss 6660 0000xxxx00x000000000000000000000000000000000000000000000000000000000000000000000000000 000s ssss7777 7 00 xx0000xxx0000000000000000000000000000000000000000000000000000000000000000000000042012080
tt 8ttt8888 00 0xx00a0xxx000080000000000000000000000000000000f100c0011000020003222ed0d050d3c065407c0044 tt t99tt 9990 0000xxxxffxfffffffffffffffffffffffffffffffffff00ff8888111111110011770000777000099990090
kkkk00k0 0000 x000xxx00x0000000000000000000000000000000000000000000000000000000000000000000000000000 00kk 1kkk1111 00 0xx0000xxx000000000000000000000000000000000000000000000000000000000000000000000000000
gg ppggg ppp 00 0xx00aaxxx8aaa88880000000000000000000000000111100107800e1888a222cf28c08c0040000000000 000 ssssppsp pp00 x000xxxxaaaa88a8008800000000000000000000011000011180000888e122ca28f3f24b7bf9bbbf9990000
s sss88s8 8800 x000xxxx0000000000000000000000000000000000000000000000000000000000000000000000002012480 0 rr aarrr aaa 0000xx0xffxxffffffffffffffffffffffffff000fffffffff88881181221133222d333dddd777711710011
ee rreeerrrrrrrr____ee_eppeeccppp ccc 0000xx0xffxxffffffffffffffffffffffffffffffffffffff8888118122113322233333333dddd00d00000 000e eeeeppppccpc cc00 x000xfxxxfffffffffffff0fffffffffffffffffffffff88ff1188811142228323e333ad3330ddd40004000
s ssssttttaatattaauutttsuuussss 00 0xx0000xxx00000000000000000000000000000000000001101001155000855588888888cc8ceecc44eee444 ccccaacauuaassuuuessseeee 00 0xx0000xxx000000000000000000000000000000000000440000444800088880000880888880088800000000
ss usssuuuummmm00m0 0000 x000xxxx0000000000000000040004444000000000000000000000000000000000000000000000000000000 0ee nneeennn0000 0 00 xx000x0xx000000000000000000000000000000000000000000000000000000000000000000000000000000
S
S
StSStattataacacckckc k kk D DuDDuDuumummpmpm:p:pp:
0 0x00x0xx0x000000000000000000000000▒
Booting..
09-27-2018 03:44 AM
12-14-2018 10:46 AM
hitting a similar issue. How did you tell that the flash is dead?
12-14-2018 03:03 PM
As per our experience we suggest the best option for your resolve in time manner.
becuase of your output show the behaviour of the device - flash is desd, these all electronic items.
So suggestion is if you have smartnet contract for this raise TAC case , TAC will investigate for you, and RMA the new one for you for quicker resolution.
hope this make sense ?
12-14-2018 03:09 PM
12-14-2018 03:11 PM
oh I see. And you also saw those "failing Bank" or whatever as well
Thank you
