Cisco 3850 Stackwise virtual issu
adnanbiek
I have two cisco 3850 mode ws-c3850-12XS-E with to 4 10G network module.
I have setup cisco stackwise virtual on those swithes via to 10G link as SVL link and one 10G as dual active detection and two switches have been stacked. I connect two 1G link from cisco 2960 switch to those cisco 3850 stacked switches,but when I setup LACP between those link the below error was appear:
l3dontbndl2: te1/1/4 suspended: lacp currently not enabled on the remote port
but now I do not know what is problem. everything for config is ok.
another thing when I unplug one link from SVL that problem will be solved.
please help me
6 Replies 6
post the configs of both switches...
Hello
I copy only part of stackswise virtual:
**3850-SW-1**
stackwise-virtual
domain 10
redundancy mode
sso
interface TenGigabitEthernet 1/0/1
switchport mode access
switchport access vlan 10
channel-group 10 mode active
interface TenGigabitEthernet 1/0/10
stackwise-virtual dual-active-detection
interface TenGigabitEthernet 1/0/11
stackwise-virtual link 1
interface TenGigabitEthernet 1/0/12
interface port-channel 10
**3850-SW-2**
stackwise-virtual
domain 10
redundancy mode
sso
interface TenGigabitEthernet 2/0/1
interface TenGigabitEthernet 2/0/10
interface TenGigabitEthernet 2/0/11
interface TenGigabitEthernet 2/0/12
**2960-SW**
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
Leo Laohoo
How is this possible?
According to Cisco documentation (02 July 2017) it states:
Cisco StackWise Virtual is supported only on the WS-C3850-48XS-S, WS-C3850-48XS-E, WS-C3850-48XS-F-S, WS-C3850-48XS-F-E models of the Cisco Catalyst 3850 Series Switches.
Yes is supported only on the WS-C3850-48XS-S, WS-C3850-48XS-E, WS-C3850-48XS-F-S, WS-C3850-48XS-F-E models of the Cisco Catalyst 3850 Series Switches. but now it is working on WS-C3850-12S-E. swithes were stacked. all feature for stack is working but only LACP problem.
Are you sure your two switches are successfully stacked?  If they were, I'd expect a single stack configuration rather than two separate switch configurations.
The command reference states that the link value of "stackwise-virtual link <link value>" should match the stackwise virtual domain. Yours shows a mismatch. That's something to fix if you're still wrestling with the problem.
Hi  cweinhold
 Thanks so much for your comment.
 could you please me what exact my problem?(syntax).
now i see i should put each link of stackwise virtual link in different value?
is that correct?
