Cisco 3850 to Cisco IE4000 Encryption
Jeff Horton
Level 3
Level 3
Researching ideas on how I can achieve switch to switch data encryption between the Cisco 3850x switch and a Cisco ie4000 switch?
Any recommendations?
Jeff
I have somewhat of a solution now on this.. Cisco Trustsec.. Enabled this on IE4000 uplink ports to C3850.
cts manual
sap pmk 1234abcdef mode-list gcm-encrypt null no-encap
Links are up and encrypted...
balaji.bandi
Cisco Cat 3850 you  can do wth MACSEC
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/37e/consolidated_guide/b_37e_consolidated_3850_cg/configuring_macsec_encryption.pdf
Not sure IE4000 have capabilities, since i have not used it before.
BB
I have seen this but I don't think the IE4000 is completely compatable with MACsec. Even though the documentation says it is.. But i have only found that when creating the key for the IE4000, you can only use hmac-sha-256 and with the 3850 its aes-256-cmac. My understanding is thats not compatable.
Maybe its more to this than what I am seeing?
jeff
cts manual
