Cisco 4000 - K2CPU Review Analyse
NICOLAS GERVY
Sometimes we had a High CPU Utilization on one of our Cisco 4000. When we did a "show processes cpu" and a "show platform health" we can see "CatK4 Mgmt LoPri and K2CpuMan Review" are on a high cpu load.
We think there is a Mac Address problem but we don't find commands to show this. We don't have "mac-address-notification" command and his log command.
Cisco Version :
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12
.2(25)EWA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Fri 04-Mar-05 16:49 by dchih
Image text-base: 0x10000000, data-base: 0x114D6074
ROM: 12.1(20r)EW1
Dagobah Revision 95, Swamp Revision 3
Do you have some commands to help to resolv problem like that, please ?
Richard Rabouin
5 Replies 5
Karthick Murugan
Hi Richard,
can you get the output of "show platform cpu packet statistics"?
Thanks & Regards,
Karthick Murugan
CCIE#39285
Thanks & Regards, Karthick Murugan CCIE#39285
Hi Karthick,
Thanks for your answer. This is the output of the command, actually the problem disappear alone... :
#sh platform cpu packet statistics
Packets Dropped In Hardware By CPU Subport (txQueueNotAvail)
CPU Subport  TxQueue 0       TxQueue 1       TxQueue 2       TxQueue 3
           0               0               0               0       239898503
           3        48161320               0               0               0
Packets Dropped In Processing Overall
Total                5 sec avg 1 min avg 5 min avg 1 hour avg
            33498997         0         0         0          0
Packets Dropped In Processing by CPU event
Event             Total                5 sec avg 1 min avg 5 min avg 1 hour avg
Input Acl                     33498933         0         0         0          0
Output Acl                          47         0         0         0          0
SA Miss                             17         0         0         0          0
Packets Dropped In Processing by Priority
Priority          Total                5 sec avg 1 min avg 5 min avg 1 hour avg
Normal                          856252         0         0         0          0
Medium                              17         0         0         0          0
High                          32642728         0         0         0          0
Packets Dropped In Processing by Reason
Reason             Total                5 sec avg 1 min avg 5 min avg 1 hour avg
UnknownLyr-OutAcl                    47         0         0         0          0
L2DstDrop                            17         0         0         0          0
AclActionDrop                  33498933         0         0         0          0
Total packet queues 16
Packets Received by Packet Queue
Queue                  Total           5 sec avg 1 min avg 5 min avg 1 hour avg
Esmp                         892511594        31        20        16          8
Control                      197314769         6         3         0          0
Host Learning                 11829630         0         0         0          0
L3 Fwd Low                     3048714         0         0         0          0
L2 Fwd Low                   262239682        16         5        21        463
L3 Rx Low                    246538680         3         0         1          0
RPF Failure                     630305         0         0         0          0
ACL fwd(snooping)           1283733180        43        30        30         29
ACL log, unreach               4503623         0         0         0          0
Packets Dropped by Packet Queue
Host Learning                     3659         0         0         0          0
L2 Fwd Low                      914516         0         0         0         78
ACL fwd(snooping)                   17         0         0         0          0
Richard Rabouin
HI Nicolas,
When the issue is happening we need to capture the output repeatedly for atleast 3 times to see the CPU queue being choked.
Once you identify the CPU queue which is choked then you can use the following command to find the source of the traffic.
debug platform packet all receive buffer
show platform cpu packet buffered
Thanks & Regards,
Karthick Murugan
CCIE#39285
Thanks for your answer,
Is this debug add some CPU load, memory load on the device which could crash him ? Is this command returns in output the interface number with high cpu load ?
Richard Rabouin
Hi Nicolas,
Those commands are meant for CPU troubleshooting and it uses a seperate asic hence it should not intterup the traffic. However, If you are still concerned then you consider doing the same OFF business hours.
Thanks & Regards,
Karthick Murugan
CCIE#39285
