02-26-2015 09:14 AM - edited 03-07-2019 10:51 PM
I bought 30 Cisco Phone SPA514G, and I have in my company a Cisco 4500 switch.
I want to connect my phone with a POE line, but I must buy a new module.
Is the module WS-X4548-GB-RJ45V a good choice?
regards
02-26-2015 10:03 AM
That module should work fine. If you need more power for your devices, than WS-X4748-UPOE-E provides up to 30 watts per port.
See figure-11 in this link;
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/catalyst-4500-series-line-cards/product_data_sheet0900aecd802109ea.html
02-26-2015 12:01 PM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
BTW, also insure your power supplies can provide the additional wattage needed by your PoE devices.
02-26-2015 07:13 PM
Yes . Also you have option of below modules. you can choose depend your requirement speed and POE power .
WS-X4248-RJ45V Catalyst 4500 PoE 802.3af 10/100, 48-Ports(RJ45)
WS-X4248-RJ21V Catalyst 4500 PoE 802.3af 10/100, 48-Ports(RJ21)
WS-X4548-GB-RJ45V Catalyst 4500 PoE 802.3af 10/100/1000, 48-Ports(RJ45)
WS-X4748-UPOE+E. Catalyst 4500E Series 48-Port 802.3af PoE, 802.3at PoEP, and UPOE 10/100/1000 (RJ-45)
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_bulletin09186a00801f3dda.html
VS.Suresh.
*Plz rate the usefull posts *
02-27-2015 04:41 AM
Ok.
Thanks for your response.
After I installed the new module, have I to configure the poe on the port, or is the poe already configured?
I'm sorry for my english
regards
Leonardo
02-27-2015 05:29 AM
After installation the POE module is ready for use. You don't need to configure anything.
