Cisco Community Designated VIP Class of 2020
265
Beginner
Cisco 4500 Chassis
All,
We are looking at 4506 chassis with 8E supervisor.
We have around 30 x 10Gb uplinks. According to Cisco datasheet it only supports 8 x 10Gb. is that right ?
Further below it lists it supports 96 uplinks 10Gb + 8 uplinks. What do they mean by uplinks?
We can't use 6800 due to cost
https://www.cisco.com/c/en/us/products/switches/catalyst-4500-series-switches/models-comparison.html
6 REPLIES 6
Re: Cisco 4500 Chassis
cisco8887,
Is this for aggregating access layer switches at 10G ?
Are you looking at a single Supervisor or dual Supervisors ?
Are you looking at a single chassis or dual chassis ?
Cheers,
Scott Hodgdon
Senior Technical Marketing Engineer
Enterprise Networking Group
Beginner
Thanks Scott
Single Sup
Dual chassis in VSS in separete geographical areas
30x 10Gb from access switches to each Chassis so 60 x 10Gb connections
model is 4506
what power supply and line card would you go for?
 cisco8887,
If I were you, I would look at the Catalyst 9500 Higher Performance model  9500-48Y4C:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9500-series-switches/nb-06-cat9500-ser-data-sheet-cte-en.html
It is non-blocking on all ports, can support 1 / 10 / 25G on all 48 downlink interfaces, 10/40/100G on the uplink interfaces, supports StackWise Virtual (same capability as VSS), has lower power consumption, lower rack profile and front-to-back airflow.
Cheers,
Scott Hodgdon
Beginner
I am thinking of it however cost is an issue
do you know the cost difference?
on 4500 it is not really an option as maximum port density is 12 ports of 10Gb as blocking card on 4500
Hall of Fame Community Legend
I understand that cost is an issue, however, what are you trying to achieve?
NOTE:  Not all chassis can support Sup8, hence, I am asking.
cisco8887,
The 9500 option should be cheaper, and we have a bundle SKU that includes 2 9500-48y4c switches + 4 40G uplink modules (can be used for StackWise Virtual as well) + 1 650W power supply in each switch + DNA Advantage 5-year license . I think the List price of this bundle will be at or below the list price of just 3 of the 12-port 10G modules for the 4506. The bundle SKU is C9500-48Y4C-A-BUN, so please work with a Cisco Partner on pricing. Caveat: I am not in sales, so pricing is not exactly my thing :-) .
Cheers,
Scott Hodgdon
Content for Community-Ad
