cisco 4500 e series with 3 -slot chasis
jaweed143
hi
every one i want to know ws-c4503E series 3 -slot chasis .I have compatabilty issues with MEM-C4K-FLD64M AND S45EIPBK9-12240SG will work or not if not please suggest the which is best  plz reply as soon as possible thanks
Amit Singh
Ghulam,
Which sup engine you are talking about? This compatibility is to with the sup engine and the IOS you are using vs the chassis being used.let's know.
jaweed143
thanks for ur qiuck reply my company requires 4500E  redundant core switch (10 G) for that some technical guy suggest that we need 1. ws-c4503E
                    2.catalyst 4500 E-series supervisor ,848gbps
                    3.catalyst 4500 E-series 12-port 10 Gbe (sfp)
                    4.spf-10g-sr
                    5.spf-10g-lrm
                    6.cvr-x2-sfp10g
                    7.glc-sx-mm
                    8.s45eipbk9-12240g
                    9.mem-c4k-fld64m
                    10.pwr-c45-2800acv
are required to setup my core network
But some cisco guy gaving different senario like from 1-8 are same,item nos 9 and 10 are different  he included 9.cat4500e  sup7e universal crypto image
10.paper ip based license
My doubt is with flash item nos 9 can we able to start a switch and plz suggest us which is the best solution thanks
