02-15-2012 06:07 AM - edited 03-07-2019 04:57 AM
New To Cisco, was a 3com shop.
I have a Cisco 4500 Sup 6 engine and I have two 48 port fiber line cards installed. When I do a show interfaces I do not see any of the Fiber cards. This is a new out of the box 4500 and I installed the Sup 6 Line card in Slot #1, And the two 48 port Fiber cards in Slots 2 and 3. Am I missing something, is there a command or set up procidure for the line cards. I just assumed they were plug and play
02-15-2012 07:51 AM
Hey Darren,
show module shows the state and status of the modules within the modular switch.
Take note of the STATUS column of the modules, if unknown, failed, not-supported ---consider reviewing the Cisco hardware manual of supported modules and IOS levels currently running. The running IOS MUST support the cards installed else, unknown or unsupported could results.
If this helps, rate it!!
Frank
02-15-2012 07:55 AM
Make sure you have the correct code and version to support those cards. Check the release notes for your version .
