ā02-18-2014 08:29 AM - edited ā03-07-2019 06:16 PM
Hi, I am Ashley and i am testing the Cisco 4500X using wireshark capture. advanced ip services IOS.
The capture runs fine when storing the wireshark file on the bootflash. No worries.
But when i configure the destination as USB0 my pendrive, it fails.
The usb device is fine and is writable. I tested it by copying from bootflash to usb0:
Followed the instructions in the config guide.
It still fails.
Can someone please help.
Solved! Go to Solution.
ā02-18-2014 01:34 PM
Could be a bug but I wouldn't recommend configuring the destination as your USB drive because no one has the same luxury as you to have the USB sit there all the time.
Store to the flash and transfer to USB is probably the best solution.
ā02-18-2014 11:29 PM
We will log a tac case with Cisco for that matter just to have this functionality to at least work.
ā02-18-2014 11:33 PM
Thanks for taking the time to rate our posts, Ashley.
