1100
Highlighted
Beginner
Cisco 4503 "1000BaseLH" SFP light is not coming ---- Urgent
Dear Team,
I have Cisco 4503 and I have inserted 1000BaseLH and light is not coming up but for 1000BaseSX its fine.
Please suggest.
CORE#show int GigabitEthernet1/18
GigabitEthernet1/18 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet Port, address is 001e.4aa6.b891 (bia 001e.4aa6.b891)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, Auto-speed, link type is auto, media type is 1000BaseLH
  input flow-control is off, output flow-control is off
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicast)
     0 packets output, 0 bytes, 0 underruns
     0 lost carrier, 0 no carrier
CORE#show inventory
NAME: "GigabitEthernet1/18", DESCR: "1000BaseLH"
PID: TRF5735AALB202    , VID: A1 , SN: OPA11241478
Thank You,
Abhisar.
1 ACCEPTED SOLUTION
Highlighted
Try connecting the cable.  Please don't look at the laser light. It will damage your eyes.
5 REPLIES 5
Highlighted
Hall of Fame Expert
Are you using the right fiber patch cored with 1000BaseLH optic?
For 1000BaseLH optic you need to use single-mode fiber?
Highlighted
Dear Reza,
I have not connected the cable yet, I am checking on the switch itself, no light on SFP.
Please suggest.
Thank You,
Abhisar.
Highlighted
Highlighted
Dear Reza, we connected cable and it came up. The conclusion is single m9de sfps does not show light where multimode sfp shows light when sfp is connected on switch port. Thank you for your suggesion. Thank You, Abhisar.
Highlighted
Glad to help Abhisar
Thanks for the rating!
Reza
Content for Community-Ad
